Implementation Failure, Artix 7, Vivado 2014.3.1
Synthesis is OK but Implementation is with the error message belows: (Artix 7, Vivado 2014.3.1)
ERROR: [Project 1-9] Cannot open structural netlist because no structural source files were specified. Edif, ngc ngo and verilog structural netlists are supported.
Tried to delete Project_1.runs directory, and rerun implementation but no help. Any suggestion is appreciated.
Thank you
Re: Implementation Failure, Artix 7, Vivado 2014.3.1
Hi @b.t.tran ,
There were multiple similar issues in Vivado 2014.x. Is there any specific reason for working with Vivado 2014.3.1?
As the latest Version of Vivado at present is 2019.1.
Raj
I wonder if you have no output for your design.
if you don't, on the Implementation process, the processor will delete your design
I am sorry I can't change another Vivado version for our application. I need to stay with Vivado 2014.3.1. Do you have other way to correct this implementation.?
Thank you,
Binh Tran
Hi @b.t.tran
Does the below Forums post help? You should be able open the routed checkpoint (open_checkpoint) if implementation has completed. I would also make sure that the top module is being recognized by Vivado.
https://forums.xilinx.com/t5/Design-Entry/Top-module-setting-lost/td-p/510195
