Implementation Failure in ISE10.1.3 (for old project in 8.1)
Hi, I use ISE10.1.3 with same options to implement an old 8.1 project. The P&R failed with the following log. The log in 8.1 is also attached. I really need the ISE10.1.3 to work at this moment. Pls help!!!
Release 10.1 par K.39 (nt)Starting Placer
Phase 1.1
Phase 1.1 (Checksum:da8264d) REAL time: 1 mins 57 secs
REAL time consumed by placer: 2 mins
CPU  time consumed by placer: 1 mins 56 secs
Total REAL time to Placer completion: 2 mins
Total CPU time to Placer completion: 1 mins 56 secs
 Generating Pad Report.
28489 signals are not completely routed.
Release 8.1.03i par I.27
# of EXACT MODE DIRECTED ROUTING found:6, SUCCESS:6, FAILED:0
Phase 1: 106859 unrouted;       REAL time: 1 mins 9 secs
Phase 2: 89563 unrouted;       REAL time: 1 mins 11 secs
Phase 3: 30412 unrouted;       REAL time: 1 mins 29 secs
Phase 4: 30412 unrouted; (91262)      REAL time: 1 mins 31 secs
Phase 5: 30486 unrouted; (2682)      REAL time: 1 mins 40 secs
Phase 6: 30499 unrouted; (697)      REAL time: 1 mins 42 secs
Phase 7: 0 unrouted; (1476)      REAL time: 3 mins 20 secs
Phase 8: 0 unrouted; (1476)      REAL time: 3 mins 35 secs
Phase 9: 0 unrouted; (1083)      REAL time: 4 mins 54 secs
Phase 10: 0 unrouted; (1083)      REAL time: 8 mins 21 secs
Phase 11: 0 unrouted; (208)      REAL time: 9 mins 37 secs
Phase 12: 0 unrouted; (208)      REAL time: 9 mins 53 secs
Phase 13: 0 unrouted; (22)      REAL time: 10 mins 59 secs
Phase 14: 0 unrouted; (22)      REAL time: 11 mins 44 secs
Phase 15: 0 unrouted; (22)      REAL time: 15 mins 1 secs
Phase 16: 0 unrouted; (22)      REAL time: 15 mins 7 secs
Phase 17: 0 unrouted; (22)      REAL time: 15 mins 13 secs
All signals are completely routed.
Re: Implementation Failure in ISE10.1.3 (for old project in 8.1)
I don't believe that this log is complete.  From my uneducated guess, seeing a timing score of (22) on the last stage of PAR may mean that you just barely didn't meet timing in 8.1; but someone more expert than I may have something better to say than that.  Regardless, linking or posting the *entire* PAR log would make it easier to tell what's going on.
Are you resynthesizing in 10.1.3 also before you re-PAR?
Thanks for reply. The synthesis is done in Synplify Pro 771 for both.
Joshua is right, even if that's not you question, you should investigate on you design.
The final timing score of 20 means that you didn't met your timing costraints.
You may try to create a new project in ISE10.1.03 against migrating it from the old 8.1 project.
You also can try different MAP or PAR options to find a work-around. Such as enable timing-driven during MAP.
