[Implementation error]
[DRC MDRV-1] Multiple Driver Nets: Net ControlWriteEn_IBUF has multiple drivers: ControlWriteEn_IBUF_inst/O, and ab/ControlWriteEn_reg/Q.
Tcl Console message:
Route information for ControlWriteEn_IBUF
  Route status: UNPLACED
  This net has no placed pins
    Unplaced Pins:
      coder1/Scratch/scratch_memory_i/blk_mem_gen_0/inst/native_mem_module.blk_mem_gen_v8_3_3_inst/async_clk_sched_clka_wf.memory[0][31]_i_14/I1
  No route tree exists for this net.
How to resolve this error.
Hi @vlsiiiitm,
From the error, it looks like the net ControlWriteEn_IBUF is being driven by both a Buffer and the Q output of a Register, which is not allowed.
Please open the synthesized schematic and try to locate those nets (you can CTRL + F the names) and see if that is really happening. If so, you'll need to modify your code to fix that.
Andre Guerrero
Product Applications Engineer
Hi @vlsiiiitm.
I would try removing the multi-driver DRC. Was this DRC severity reduced? I would expect this to stop the flow before route_design. It could be helpful to open the elaborated design, and follow the net to both drivers. One of them should be removed.
