vivek
Implementation of very large matrix operation in FPGA
Hello everyone,
I am trying to implement a very large matrix multiplication, addition, subtraction and division design on FPGA.
This matrix are large as 16x10 with each element being a 16 bit binary number.
My challenge here is that every time I multiply two matrices , the size of each element of the resultant matrix increases a lot!
What is the approach to implement this design?
balkris
this is expected behavior and one of the challenge in dsp application / you can try rounding , truncation. use right shift to make it simple but impact precision
Thanks and Regards
Balkrishan
balkris
Thanks and Regards
Balkrishan
vivek
Thank you @balkris.
