khyu
Increamental complie only for sub module , not for the whole chip
I use the increamental compile only for usb module , not the whole chip because the usb timing is critical.
So I use the following tcl script in post tcl of design initialization
read_checkpoint -incremental /home/ittmp1/khyu/fpga/aab033_khyu/VU440_FPGA16_IOB_r286_dram_nc_slr/aab033/checkpoint_1.dcp -reuse_objects [get_cells u_coreb033/u_usbtop/* ]
It work first, but fail at rout design . I got the error message.
ERROR: [Vivado_Tcl 4-384] DRC checks failed. Netlist or placement errors exist in this design. Please correct these errors before proceeding.
I update the my script to
But I got the same error
How can I do if I only want to refer to sub module , not the whole chip in increamtal comipler?
Thank you
surajc
Hi @khyu
You are using read_checkpoint in a pre-hook TCL before place_design, this is not a recommended method of using the incremental implementation in project mode.
Please see this link to know about how to use Incremental Implementation in Project Mode.
Once you set the Incremental Checkpoint by the method mentioned in the link simply select the design run in the vivado GUI, go to its properties and add
-reuse_objects [get_cells <cell_name>] in more options, Shown in attached image.
Once this is done confirm the same in runme.log whether read_checkpoint -incremental -reuse_objects [get-cells <>] ./.....dcp is ran after opt_design or not.
Please try this and let us know
surajc
Hi @khyu ,
For using the incremental on a sub-module of the design, the option -reuse_objects is the correct option. So you are using the tool correctly but since the design is failing during routing ( even when the whole design is being reused ) you should debug on the cause of the DRC failure and routing failure.
Can you show us the DRC error you are getting?
khyu
Hi Surajc:
         Error message is
         ERROR: [DRC NDRV-1] Driverless Nets: Undriven nets found. Running opt_design will clean up the undriven nets from your design. Please ensure that opt_design has been run on your design and check the remaining
nets for DONT_TOUCH properties. The undriven nets in your design are: Net u_gckrst/u_coreb033_1/pclk_nx_out2_ are undriven.
The message tell I have driverless nets. and must run opt_design before router.
But I enable the opt_design
I check runme.log  command flow
Command: link_design -top aab033 -part xcvu440-flga2892-2-e
Command: read_checkpoint -incremental /home/ittmp1/khyu/fpga/aab033_khyu/VU440_FPGA16_IOB_r286_dram_nc_slr/aab033/checkpoint_1.dcp
Command: report_drc -file aab033_drc_opted.rpt -pb aab033_drc_opted.pb -rpx aab033_drc_opted.rpx
Command: place_design -directive ExtraPostPlacementOpt
Command: phys_opt_design -directive AlternateFlowWithRetiming
Command: route_design -directive Explore
There is no opt_design command when I use the tcl command to execute the readcheckpoint  command
If I use normal incremental flow , opt_design is executed
Command: opt_design
Command: report_drc -file aab033_drc_routed.rpt -pb aab033_drc_routed.pb -rpx aab033_drc_routed.rpx
Command: report_methodology -file aab033_methodology_drc_routed.rpt -pb aab033_methodology_drc_routed.pb -rpx aab033_methodology_drc_routed.rpx
Command: report_power -file aab033_power_routed.rpt -pb aab033_power_summary_routed.pb -rpx aab033_power_routed.rpx
surajc
Hi @khyu ,
Seems like after reading the reference DCP there are some nets in the design ( probably in the sub-module added as a reference for Incremental Compile ) which are not driven.
Can you make sure that opt_design is run before reading the Incremental Checkpoint for the Sub-module? and Let us know ( try working on post-synth dcp with the following flow -> link_design -> opt_design -> read_checkpoint -> place..... )
Once we resolve the driverless nets issue by adding opt_design inflow, then we can look why opt is not running.
khyu
Hi Surajc:
                   I find the read_checkpoint tcl command must be placed at the tcl.pre of place design , not at the tcl.post of design initialization.
ie . correct flow is
design initial
opt_design
read_checkpoint
place_design
surajc
Hi @khyu
