Visitor bzuiss
Incremental Compile Reference Checkpoint
I am having issues using a non-project flow incremental compile.
When I run the following:
launch_runs -to_step opt_design $the_runs -jobs 2
wait_on_run $the_runs
read_checkpoint -incremental ./design_routed.dcp
I receive the following error message:
ERROR: [Runs 36-406] Could not open the file './.Xil/Vivado-17829-mylinuxbox/incrSynthDcp/dcp.xml' for writing
However I cannot find this file in my design...should it exist?
Re: Incremental Compile Reference Checkpoint
Hi, @bzuiss ,
In non-project, you need to manage your source files by yourself.
launch_runs/wait_on_run commands are only for project mode.
You can try the below command and check whether the issue still occurs:
open_checkpoint opt.dcp
place_design
route_design
The file in the error message is in the temp dir and extracted by your reference design. If the error still occurs, you have to suspect whether the reference design is valid.
Hi, @bzuiss ,
place_design
route_design
@bzuiss
You are mixing project mode and non-project mode commands which could be the reason for error:
Check Incremental Compilation topic in below UG:
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_2/ug904-vivado-implementation.pdf#page=94
Page 102 has the example command for project and non project mode.
Check if the below sample helps:
set_property incremental_checkpoint post_routed.dcp [get_runs impl_1]
launch_runs impl_1 -jobs 4
wait_on_run impl_1
--Syed
Visitor bzuiss
Thanks to both of you, my existing project was using a project flow and I ended up replacing my command with:
set_property incremental_checkpoint ./project_routed.dcp [get_runs impl1]
Newbie 2mphtijlc
Replace the launch_runs scripts with their incremental version. The problem is that reset_run (which is called by the GUI first) removes .dcps, which means reuse before actually calling_runs. This makes these scripts useless in most cases, 156-315.80 Dumps Questions unless the user is running launch_runs without reset_runs in the Tcl console.
