Visitor yuriom
Is there a reliable way to lock LUT6_2's to specific BEL's/sites?
Is there a reliable way to lock LUT6_2's to specific BEL's? I tried using various combinations of the LOC, BEL, and DONT_TOUCH properties without much success. I am targeting VCU-1525 with Vivado 2018.3.
Re: Is there a reliable way to lock LUT6_2's to specific BEL's/sites?
Hi @yuriom ,
You can achive that using GUI by selecting the "Fixed" property of LUT instance as shown below:
After this save the constraints, the below constraints will be added to XDC.
set_property BEL A6LUT [get_cells {arnd1/transformLoop[0].ct/xOutReg_reg_i_17}]
set_property LOC SLICE_X12Y163 [get_cells {arnd1/transformLoop[0].ct/xOutReg_reg_i_17}]
Raj
Visitor yuriom
Hi @rshekhaw  ,
I know I can do this with LUT[1-5]. My question is specifically about LUT6_2. It seems like Vivado treats each LUT6_2 as a combination of a LUT5 and a LUT6, and complains about the site being occupied already.
Hi, @yuriom ,
You can refer to LUTNM in UG903 to pack the LUTs first:
A unique string name applied to two LUTs to control their placement on a single LUT
site. Unlike HLUTNM, LUTNM can be used to combine LUTs that belong to different
hierarchical cells.
Are you instantiating a LUT6_2 instance in your RTL code?
Or is it an inferred LUT6_2?
What is the LUT objects like in the netlist?
What constraints did you try and what error did you received?
-vivian
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
