mmatusov
Voyager
Voyager
Is there a way in Vivado to add physical probe pins to an implemented design?
This used to be possible in FPGA Editor. What is the best approach in Vivado?
/Mikhail
hongh
Hi, @mmatusov ,
You can try to use the command to modify the routed design directly.
Tools -> Xilinx tcl Store -> Debug Utilities (Install it and you can run the provided command xilinx::debugutils::add_probe )
hongh
Hi, @mmatusov ,
mmatusov
Voyager
Voyager
Thanks!
