Is there any method to directly disable or downgrade the severity of RTSTAT DRCs?
Hi there,
I am working on Vivado. I am wondering if there is any possible way to disable the RTSTAT DRCs.
I know that these RTSTAT DRCs are related to some errors about routing (e.g. partially routed nets). Besides, they are read-only and will hinder the bitstream generation.
Hope someone can tell me how to let Vivado ignore these checks. Thanks!
rshekhaw
Hi zht247200@gmail.com ,
Yes you can disable them:
set_property IS_ENABLED 0 [get_drc_checks {<>}]
Check the below AR# link:
https://www.xilinx.com/support/answers/51543.html
Raj
anunesgu
Adding to @rshekhaw answer, you can also demote the error with the following command:
set_property SEVERITY {Warning} [get_drc_checks <>]
With the command above, you are able to downgrade an Error or Critical Warning to a "regular" Warning, which will allow you to proceed with bitstream generation.
The advantage is that the warning will still be there so you hopefully look at it in the future and fix it.
Andre Guerrero
Product Applications Engineer
hongh
Hi, zht247200@gmail.com ,
 I don't think RTSTAT related DRC can be disabled to generate bitstream.
Hi Raj,
Thanks for your reply.
 The method should be feasible for disabling those DRC rules which are not read-only. But as I said, the RTSTAT DRCs are read-only and thus cannot be disabled by such a tcl command. What I'm trying to do is to see if there is any possible way to disable those DRCs.
ZHT
Hi Andre,
As I said, the RTSTAT DRCs are read-only and thus cannot be downgraded by your command.
I have tried that way but it didn't work.
ZHT
Hi hongh,
You may be absolutely right. But I am trying to see if anyone knows some weird methods even bugs in Vivado to enable doing so.
ZHT
rshekhaw
Apologies my bad.
Then i guess the only way is to debug those partial route DRCs. Check the below AR# if that can help:
https://www.xilinx.com/support/answers/53854.html
Raj
