Visitor amirtofighiz
JESD204B TI Reference design Error building the design
Hi There,
I am trying to work with the JESD204B TI Reference design that can be found at,
http://www.ti.com/tool/tsw14j10evm
You can find it at the bottom of the page: TSW14J10EVM Xilinx Firmware Source (Rev. C) (it is also attached).
I am using a TI ADC12J4000 through a TSW14J10 FMC board and connecting it to a KC705 Xilinx FPGA board.
Going through the PDF file attached, while running the command   "source ./script/build_it.tcl", I run into the following error:
[Common 17-70] Application Exception: Failed to launch run 'impl_1' due to failures in the following run(s):
synth_1
These failed run(s) need to be reset prior to launching 'impl_1' again.
I would appreciate it if somebody could help me understand what this error is.
Amir
P.S. I am attaching the log as well.
Re: JESD204B TI Reference design Error building the design
@amirtofighiz
Check the synthesis log file and see if there are any errors. From log file, I see the following message:
ERROR: [Common 17-70] Application Exception: Failed to launch run 'impl_1' due to failures in the following run(s):
synth_1
How are you running the design in Vivado? Open the Vivado project using .xpr file and run synthesis and implementation.
--Syed
