LUT cell generated in implementation
I used a STARTUPE2 primitive in project. I opened the IMPLEMENTED DESIGN, why it generated STATRUPE2_inst_i_1 which is LUT cell (just as pic.1), while sometime, it just has only one cell (pic.2).Screen Shot 2019-09-04 at 1.35.16 PM.png
pic.1
pic.2
@yinglu2
Click on the STARTUPE2_inst_i_1(LUT5) cell and press F4 to see the schematic for its connections. I believe the implementation must be inserting the LUT cell during optimization. The information will be present in the log file.
The pic2 without LUT5 must be from synthesized design.
--Syed
Thanks for your reply.
And the pic.2 is indeed opened in IMPLEMENTED DESIGN.
@yinglu2
If pic2 is from implemented design then can you confirm pic1 is from synthesized design which has LUT5 cell?
Can you add -verbose switch under more options for opt_design and place_design in implementation settings as shown below. Rerun implementation and share the runme.log file which will be present in your project.runs folder:
Example <project>/<project>.runs/impl_1/runme.log file.
--Syed
