LVDS P and N swapping in the FPGA
Hello Guys,
i have the following problem:
I'm using 1G/2.5G Ethernet PCS/PMA or SGMII IP Core. RXN and RXP are connected to fix FPGA pins.
Unfortunatelly there is a mistake on the PCB layout. P and N are swapped.
So i have to swapp it again in the FPGA somehow. The Problm is, that the IP core doesn't allow me to connect RXN to a P pin.
After a look in the schematic, it generates the IBUFDS in the core
So i cannot invert the Signals after the IBUFDS because it's protected in the ip core source.
I tried to instanciate an own IBUFDS bevore the SGMII IP core.
But this work-around doesn't work because vivado complains about it:
Could you tell me why solution doesn't work?
And could you tell me what can i do otherwise?
Thank you very much.
best regards
Alex
Mentor jmcclusk
Mentor
Re: LVDS P and N swapping in the FPGA
It seems plausible that you can insert an inversion stage on gmii_rxd.    Is your TX interface also inverted?    Even if the IP is encrypted, you might still be able to modify the netlist using a TCL script.
Mentor jmcclusk
Mentor
Flexibility at the IO interfaces is much more limited than in the fabric.  You'll probably have to invert the signal AFTER the IO cells, which means inverting 4 or 8 bits of data, after it's been deserialized.
thanks for your reply,
the problem is, that the sources of the IP Core are encrypted. So i cannot invert the signal after the io cells.
Does anyone has another idea, how to solve the problem?
What is with the Data channels from the IP?
gmii_rxd and gmii_txd. Can i invert them? Does it make sence?
Thank you all
Mentor jmcclusk
Mentor
Yes, my TX interface is also inverted.
The idea with the TCL script sounds good. I will try it out, thanks.
Better solution for me would be to set it by a constraint.
