LVDS output differential voltage is too high
I am using Vivado 2019.1 and am developing a project for the Zynq Ultrascale+.
In my Vivado project, I have pins driven by OBUFDS primitives that are set to LVDS. According to UG925, the differential mode output voltage should be ~350 mV, and the output common mode voltage should be about ~1.25 V.
Using a differential probe, I am seeing the following voltages. The differential mode voltage is ~700 mV.
According to Vivado, the pins are set to LVDS mode:
What am I doing wrong/misunderstanding?
Re: LVDS output differential voltage is too high
@joelschad
VODIFF is the voltage swing (in one line) between high and low, or, between + and - lines, as they will always be opposite.
When a differential signal is translated to single ended (i.e. subtracted), it produces a +/- VODIFF signal, so what you see on a scope with a differential probe (that translates from diff to single ended) is a jump of 2x VODIFF.
If you just probed a line, you will see the 350 - 400 mV swing.
Are your signals terminated at the receiving side?
Yes, I have them set up with off-chip FD_100 termination in Vivado's Implementation flow, and I have 100Ω resistors across the pins on the breakout board I'm using to observe the signals.
Do you have a differential buffer driving in your fpga.
One thought, and Im to tired to think this through, Appologies.
Is it the differential probe effect ?
As one side goes up 350 mV, the other goes down 350 mV,
so the probe sees that as 700 mV difference ?
Wonder what a single ended probe on one would show ?
I think you're right.
I went back and looked at a differential signal on a Zynq 7 design and saw the same 2x-my-expectation voltages. The DS925 description implies that the Q-Q' voltage is only 350 mV nominal, but, as you said, the voltage swing on each channel is 350 mV nominal, for total swing of 700 mV.
This diagram shows the expected waveforms, and several app notes confirm this.
@joelschad
And to just drive this home, the Xilinx datasheet is also telling you the same.
Where this snippet highlighted is the impotant bit. i.e.
Which is basically saying the 350mV figure is the abs value. So, using the numbers from that diagram you posted:
when Q is high the figure is taken from Q - ~Q = 1.35-1.05 = 300mV, and when ~Q is high the number is again1.35 - 1.05 = 300mV
