MAP removes BRAM during optimization
I have a project on a V5FX30T and some problem with the map process.
It has an instance of the MicroBlaze, LMB,  PLB-Bus and some BRAM using the lmb_bram_if_ctrl in Xilinx XPS EDK.
When I enable -global_opt (no matter if speed or area), the map report shows me a lot of removed logic, and also removes the block ram used by the microblaze.
The -gloab_opt option saves a lot of logic resources, but why is it removing my blockram?
The bram instance name is "bram_app_mb" and the instance of the lmb-ctrl is "dlmb_ctrl_bram_mb" and "ilmb_ctrl_bram_mb"
Map report shows alot of messages like this:
Loadless block "bram_app_mb" (bram_app_mb_wrapper) removed.
 The signal "dlmb_mb_M_ABus<0>" is loadless and has been removed.
 The signal "dlmb_mb_M_ABus<1>" is loadless and has been removed.
 The signal "dlmb_mb_M_ABus<2>" is loadless and has been removed.
 The signal "dlmb_mb_M_ABus<3>" is loadless and has been removed.
 The signal "dlmb_mb_M_ABus<4>" is loadless and has been removed.
 The signal "dlmb_mb_M_ABus<5>" is loadless and has been removed.
 The signal "dlmb_mb_M_ABus<6>" is loadless and has been removed.
 The signal "dlmb_mb_M_ABus<7>" is loadless and has been removed.
 The signal "dlmb_mb_M_ABus<8>" is loadless and has been removed.
 The signal "dlmb_mb_M_ABus<9>" is loadless and has been removed.
 The signal "dlmb_mb_M_ABus<10>" is loadless and has been removed.
 The signal "dlmb_mb_M_ABus<11>" is loadless and has been removed.
 The signal "dlmb_mb_M_ABus<12>" is loadless and has been removed.
 The signal "dlmb_mb_M_ABus<13>" is loadless and has been removed.
 The signal "dlmb_mb_M_ABus<14>" is loadless and has been removed.
 The signal "dlmb_mb_M_ABus<15>" is loadless and has been removed.
 The signal "dlmb_mb_M_ABus<16>" is loadless and has been removed.
 The signal "dlmb_mb_M_ABus<17>" is loadless and has been removed.
 The signal "dlmb_mb_M_ABus<18>" is loadless and has been removed.
 The signal "dlmb_mb_M_ABus<19>" is loadless and has been removed.
 The signal "dlmb_mb_M_ABus<20>" is loadless and has been removed.
 The signal "dlmb_mb_M_ABus<21>" is loadless and has been removed.
 The signal "dlmb_mb_M_ABus<22>" is loadless and has been removed.
 The signal "dlmb_mb_M_ABus<23>" is loadless and has been removed.
 The signal "dlmb_mb_M_ABus<24>" is loadless and has been removed.
 The signal "dlmb_mb_M_ABus<25>" is loadless and has been removed.
 The signal "dlmb_mb_M_ABus<26>" is loadless and has been removed.
 The signal "dlmb_mb_M_ABus<27>" is loadless and has been removed.
 The signal "dlmb_mb_M_ABus<28>" is loadless and has been removed.
 The signal "dlmb_mb_M_ABus<29>" is loadless and has been removed.
Unused block "bram_app_mb/XST_GND" (ZERO) removed.
Unused block "bram_app_mb/XST_VCC" (ONE) removed.
Unused block "bram_app_mb/bram_app_mb/XST_GND" (ZERO) removed.
Unused block "bram_app_mb/bram_app_mb/XST_VCC" (ONE) removed.
Unused block "bram_app_mb/bram_app_mb" (bram_app_mb_elaborate) removed.
The signal "bram_app_mb/BRAM_Din_A<0>" is sourceless and has been removed.
The signal "bram_app_mb/BRAM_Din_A<1>" is sourceless and has been removed.
The signal "bram_app_mb/BRAM_Din_A<2>" is sourceless and has been removed.
The signal "bram_app_mb/BRAM_Din_A<3>" is sourceless and has been removed.
The signal "bram_app_mb/BRAM_Din_A<4>" is sourceless and has been removed.
The signal "bram_app_mb/BRAM_Din_A<5>" is sourceless and has been removed.
The signal "bram_app_mb/BRAM_Din_A<6>" is sourceless and has been removed.
The signal "bram_app_mb/BRAM_Din_A<7>" is sourceless and has been removed.
The signal "bram_app_mb/BRAM_Din_A<8>" is sourceless and has been removed.
The signal "bram_app_mb/BRAM_Din_A<9>" is sourceless and has been removed.
The signal "bram_app_mb/BRAM_Din_A<10>" is sourceless and has been removed.
The signal "bram_app_mb/BRAM_Din_A<21>" is sourceless and has been removed.
The signal "bram_app_mb/BRAM_Din_A<22>" is sourceless and has been removed.
The signal "bram_app_mb/BRAM_Din_A<23>" is sourceless and has been removed.
The signal "bram_app_mb/BRAM_Din_A<24>" is sourceless and has been removed.
The signal "bram_app_mb/BRAM_Din_A<25>" is sourceless and has been removed.
The signal "bram_app_mb/BRAM_Din_A<26>" is sourceless and has been removed.
The signal "bram_app_mb/BRAM_Din_A<27>" is sourceless and has been removed.
The signal "bram_app_mb/BRAM_Din_A<28>" is sourceless and has been removed.
The signal "bram_app_mb/BRAM_Din_A<29>" is sourceless and has been removed.
The signal "bram_app_mb/BRAM_Din_A<30>" is sourceless and has been removed.
The signal "bram_app_mb/BRAM_Din_A<31>" is sourceless and has been removed.
The signal "bram_app_mb/N2" is sourceless and has been removed.
The signal "bram_app_mb/N3" is sourceless and has been removed.
The signal "bram_app_mb/bram_app_mb/N0" is sourceless and has been removed.
The signal "bram_app_mb/bram_app_mb/N1" is sourceless and has been removed.
This is how the microblaze is instantiated in the mhs-file: (there are more peripherals on the plb_microblaze)
BEGIN microblaze
 PARAMETER INSTANCE = microblaze_1
 PARAMETER HW_VER = 8.00.b
 PARAMETER C_NUMBER_OF_PC_BRK = 0
 PARAMETER C_CACHE_BYTE_SIZE = 2048
 PARAMETER C_DCACHE_BYTE_SIZE = 2048
 PARAMETER C_AREA_OPTIMIZED = 0
 PARAMETER C_USE_HW_MUL = 0
 PARAMETER C_USE_MSR_INSTR = 0
 PARAMETER C_USE_PCMP_INSTR = 0
 BUS_INTERFACE DPLB = plb_microblaze
 BUS_INTERFACE DLMB = dlmb_mb
 BUS_INTERFACE ILMB = ilmb_mb
 PORT MB_RESET = MB_reset
END
BEGIN plb_v46
 PARAMETER INSTANCE = plb_microblaze
 PARAMETER HW_VER = 1.05.a
 PARAMETER C_P2P = 1
 PORT PLB_Clk = clk_100_0000MHzPLL0_ADJUST
 PORT SYS_Rst = sys_bus_reset
END
BEGIN bram_block
 PARAMETER INSTANCE = bram_app_mb
 PARAMETER HW_VER = 1.00.a
 BUS_INTERFACE PORTA = ilmb_ctrl_bram_2_BRAM_PORT
 BUS_INTERFACE PORTB = dlmb_ctrl_bram_2_BRAM_PORT
END
BEGIN lmb_bram_if_cntlr
 PARAMETER INSTANCE = ilmb_ctrl_bram_mb
 PARAMETER HW_VER = 2.10.b
 PARAMETER C_BASEADDR = 0x00000000
 PARAMETER C_HIGHADDR = 0x00007FFF
 BUS_INTERFACE SLMB = ilmb_mb
 BUS_INTERFACE BRAM_PORT = ilmb_ctrl_bram_2_BRAM_PORT
END
BEGIN lmb_v10
 PARAMETER INSTANCE = ilmb_mb
 PARAMETER C_EXT_RESET_HIGH = 1
 PORT LMB_Clk = clk_100_0000MHzPLL0_ADJUST
END
BEGIN lmb_v10
 PARAMETER INSTANCE = dlmb_mb
END
 PARAMETER INSTANCE = dlmb_ctrl_bram_mb
 BUS_INTERFACE SLMB = dlmb_mb
 BUS_INTERFACE BRAM_PORT = dlmb_ctrl_bram_2_BRAM_PORT
END
Re: MAP removes BRAM during optimization
Does this also happen, without g.o. enabled?
Without global_opt, everything is fine. I don't get why map removes my block_ram. This is reproducable, the only cahnges is the global_opt switch.
