Make MAP use dedicated hardware from behavioral code
I've written a 32 bit synchronous adder in VHDL with behavioral description. I'm implementing the design for a Spartan-6, and I would like to use the DSP48A1 slice instead of general logics. After synthesis, I see a 32 bit asynchronous adder and a 32 bit register. After implementation, I get only LUTs instead of a DSP slice. Someone told me there is a guide about writing such code that the tools will recognize as dedicated hardware. I'm speaking about behavioural description, I know it can be also done with structural description with instantiation template.
Thank you for your help,
Václav
Re: Make MAP use dedicated hardware from behavioral code
You can use USE_DSP48 attribute in HDL to force implementation of logic on to DSP.
Refer to page-443 of http://www.xilinx.com/support/documentation/sw_manuals/xilinx14_2/xst_v6s6.pdf for details on constraint usage.
Deepika.
Deepika.
Deepika.
Deepika.
Thank you very much, it works. I added within the entity declaration:
    attribute use_dsp48 : string;
    attribute use_dsp48 of Adder : entity is "yes";
The only thing I don't understand is why is the DSP slice implementation slower than the LUT implementation? I thought dedicated hardware would be always faster than general logics.
Historian
Historian
Perhaps it's the routing into the adder that's the slow part. Make sure the adder input is registed.
I made the output registered and not the input. I want a single cycle adder, so I can't have both.
Historian
Historian
remember how the timing analyzer calculates the period. It's from one register's Q output, through whatever logic, to the next register's D input. If there is "stuff" before your inputs hit the adder's inputs, that "stuff" adds to the prop delay.
Your choices include pipelining, accepting the reduced operating frequency, and accepting the latency.
