Map failed with Pack:2811 error after enabling Global Optimization
I am using ISE/EDK 14.2 with a Spartan-6
My project has been building fine and I had just completed a successful build and the code runs fine in the Spartan-6.
Without making any other changes I turned on "Global Optimization"  for Map and did a "Rerun All".
Map failed with Pack:2811 error.
It complained about several of my signals one example is below.
ERROR:Pack:2811 - Directed packing was unable to obey the user design
   constraints (LOC=V17) which requires the combination of the symbols listed
   below to be packed into a single IOB component.
   The directed pack was not possible because: More than one pad symbol.
   The symbols involved are:
   	BUF symbol "o_DBG_0_OBUF" (Output Signal = o_DBG<0>)
   	PAD symbol "o_DBG<0>" (Pad Signal = o_DBG<0>)
   	PAD symbol "o_DBG<1>" (Pad Signal = o_DBG<1>)
   	PAD symbol "o_DBG<2>" (Pad Signal = o_DBG<2>)
   	PAD symbol "o_DBG<3>" (Pad Signal = o_DBG<3>)
   	PAD symbol "o_DBG<4>" (Pad Signal = o_DBG<4>)
   	PAD symbol "o_DBG<5>" (Pad Signal = o_DBG<5>)
   	PAD symbol "o_DBG<6>" (Pad Signal = o_DBG<6>)
   	PAD symbol "o_DBG<7>" (Pad Signal = o_DBG<7>)
   	PAD symbol "o_DBG<8>" (Pad Signal = o_DBG<8>)
   	PAD symbol "o_DBG<9>" (Pad Signal = o_DBG<9>)
   	PAD symbol "o_DBG<10>" (Pad Signal = o_DBG<10>)
   	PAD symbol "o_DBG<11>" (Pad Signal = o_DBG<11>)
   	PAD symbol "o_DBG<12>" (Pad Signal = o_DBG<12>)
   	PAD symbol "o_DBG<13>" (Pad Signal = o_DBG<13>)
   	PAD symbol "o_DBG<14>" (Pad Signal = o_DBG<14>)
   	PAD symbol "o_DBG<15>" (Pad Signal = o_DBG<15>)
 My design runs just fine, why does turning on this optimization cause an issue?
I would like to enable the optimization if possible.
Any suggestions?
Professor
Professor
Re: Map failed with Pack:2811 error after enabling Global Optimization
This looks like an error I've seen before.  It happens when you have multiple output ports
driven by the same logical signal.  Somehow with global optimization turned on, the
output buffers get merged into one and then can't be placed into multiple IOB's.  One
workaround is to make sure that each bit of your o_DBG vector has a different function
so optimization cannot merge them.
-- Gabor
-- Gabor
Ok, this is starting to sound related to the LOC and UCF bug workaround I had to do a while back.
Check there any BEL constraints on the LUTs. if there any then Remove these allowed it to go through the tool.
An alternative workaround would be to use LUT5 and LUT6 instead of LUT6_2.
hi,
check whether two pins are locked at the same location.
Duplicate LOC assignments in the UCF file.  Turned out to be the cause of Pack:2811 error in my case.  Thanks for the tip!
Len
Same here -  cause was duplicate pin assignments in UCF. Whoops. Too bad there wasn't a LINT for UCF's.
