Map fails but map report has no error messages
I am running ISE 14.7 using a supported Spartan 6 part. Synthesis and Translation succeed. Map fails yet there are no error messages onthe console or in the map report. I don't know what to do to fix it because the tool is not giving me any error messages.
Below are the console messages
Started : "Translate".
Running ngdbuild...
Command Line: ngdbuild -intstyle ise -dd _ngo -nt timestamp -a -uc src/toplevel_locked.ucf -p xc6slx4-cpg196-2 toplevel.ngc toplevel.ngd
Command Line: C:\Xilinx\14.7\ISE_DS\ISE\bin\nt64\unwrapped\ngdbuild.exe
Reading NGO file "C:/Xilinx_projects/led_controller_01/toplevel.ngc" ...
Gathering constraint information from source properties...
Done.
Annotating constraints to design from ucf file "src/toplevel_locked.ucf" ...
Resolving constraint associations...
Checking Constraint Associations...
Done...
Checking expanded design ...
Partition Implementation Status
No Partitions were found in this design.
NGDBUILD Design Results Summary:
Number of errors: 0
Number of warnings: 0
Writing NGD file "toplevel.ngd" ...
Total REAL time to NGDBUILD completion: 3 sec
Total CPU time to NGDBUILD completion: 3 sec
Writing NGDBUILD log file "toplevel.bld"...
NGDBUILD done.
Process "Translate" completed successfully
Started : "Map".
Running map...
Command Line: map -intstyle ise -p xc6slx4-cpg196-2 -w -logic_opt on -ol high -t 1 -xt 0 -r 4 -global_opt area -equivalent_register_removal on -mt off -detail -ir off -pr b -lc auto -power off -o toplevel_map.ncd toplevel.ngd toplevel.pcf
Using target part "6slx4cpg196-2".
Running global optimization...
Mapping design into LUTs...
Running directed packing...
Process "Map" failed
Hi All following this thread,
I uninstalled the tool and then re-installed it and the problem is solved. I now get a successful process all the way to generating a programming file.
Robin
syedz
robin_bordow@yahoo.com
Can you try after clearing the temp files? Project > Cleanup Project Files.. Also share the MAP file and MRP file which should be present in ISE project directory.
--Syed
ghasemi_r
make sure about the correctness of the UCF file
and regenerate your project and create special place for your file and then attach files to the new project.
I think software has some confusion.
I did the cleanup as you suggested but no change in the behavior. Below are the .map and .mrp files
here is .map file
Release 14.7 Map P.20131013 (nt64)
Xilinx Map Application Log File for Design 'toplevel'
Design Information
Command Line : map -intstyle ise -p xc6slx4-cpg196-2 -w -logic_opt on -ol high
-xe n -t 1 -xt 0 -register_duplication off -r 4 -global_opt off -mt off -detail
Target Device : xc6slx4
Target Package : cpg196
Target Speed : -2
Mapper Version : spartan6 -- $Revision: 1.55 $
Mapped Date : Wed Oct 30 01:25:43 2019
here is .mrp file
Xilinx Mapping Report File for Design 'toplevel'
Design Information
Target Speed : -2
I completely created a new project in a new directory. The .UCF file appears to be fine. I get the same problem Map fails but there are no error messages
syedz
Can you share the archive project of ISE to test this at our end? Project --> Archive
--Syed
I have commented out all the unused pins and constraints so the project is minimal. Attached is the archived project
ghasemi_r
I implement your project and there is 4 error
I am not sure about your FPGA number but I think you choose the wrong pin for clocks
syedz
Attached is the log file. I used ISE 14.7 on linux machine. Are you using supported OS with ISE?
https://www.xilinx.com/support/answers/18419.html
--Syed
Hi Syed,
Thanks for your help so far. I am using a Windows 7 OS. In order to simplify this as much as possible so as to just get to the bottom of why Map is failing, I stripped everything out of the design so that that it is just basically one flipflop. There is a data_in, a clock_in, and a data_out signal. I have attached the new archive. It seems like when you tried it on your system, the errors you got were placement errors, indicating you successfully got through the Map process.
Now that my design is as simple a test case as is humanly possible, and I am still getting a Map failure, I'm hoping you can help me figure out why.
Thanks Again, Robin
Robin
