Observer vjose
Mapping Error
Hi ,
I have an IP core from a third party . When I try to generate a bit file using this IP core , I get the following error
ERROR:Pack:2811 - Directed packing was unable to obey the user design
   constraints (MACRONAME=U_PCD03V_U_INT3G/U_INT3G4, RLOC=X1Y0) which requires
   the combination of the symbols listed below to be packed into a single SLICE
   component.
With regards
Vintu
Observer vjose
Re: Mapping Error
Hi ,
Thanks for the link .
I tried to clean the project again and run . No things are working fine .
Thanks for the help
With regards
Vintu
Re: Mapping Error
Do you have any RLOC constraints in the design?
try running map with "-ir all" switch.
Re: Mapping Error
You didn't provide the entire message so all we know is that RLOC constraints are causing the problem. The message also describes the nature of the conflict and lists the instances involved.
Are you instantiating the core more than once? If so, the provider may have used the U_SET grouping attribute for the macro which would cause the multiple instantiations to overlap.
http://www.xilinx.com/support/answers/29711.htm
Observer vjose
Re: Mapping Error
Hi ,
Thanks for the help
With regards
Vintu
Re: Mapping Error
Is it working or not working?
Please indicate properly.
