Mapping issues after upgrading to ISE14.7
Hi All,
I have come across some mapping issues with my design which used to run fine in older version of ISE. Due to some issues the tool has been moved to another server and upgraded to 14.7. When I open the old .ise project file the tool automatically converts it into .xise compatible. The synthesis and translate was success. But it threw MAP errors. Any idea why this is happening?
I have attached the error snapshot.
Swathi
I'm afraid that the tool is correct.
W24     17      IO_L4P_17
U24     13      IO_L15P_13
These are not the VAUX sites
The pin name should have an _SMnP/_SMnN
For example in this package the AUX inputs are in bank 11 and 13.
G20 11 IO_L0P_11
F20 11 IO_L0N_11
E21 11 IO_L1P_11
E20 11 IO_L1N_11
E22 11 IO_L2P_11
E23 11 IO_L2N_11
F22 11 IO_L3P_11
F23 11 IO_L3N_11
G21 11 IO_L4P_11
G22 11 IO_L4N_VREF_11
H21 11 IO_L5P_11
H22 11 IO_L5N_11
J19 11 IO_L6P_11
H19 11 IO_L6N_11
H23 11 IO_L7P_11
J23 11 IO_L7N_11
J21 11 IO_L8P_CC_11
J20 11 IO_L8N_CC_11
K21 11 IO_L9P_CC_11
K20 11 IO_L9N_CC_11
K23 11 IO_L10P_CC_SM15P_11
K22 11 IO_L10N_CC_SM15N_11
L20 11 IO_L11P_CC_SM14P_11
L19 11 IO_L11N_CC_SM14N_11
L23 11 IO_L12P_VRN_11
L22 11 IO_L12N_VRP_11
M22 11 IO_L13P_11
M21 11 IO_L13N_11
P19 11 IO_L14P_11
N19 11 IO_L14N_VREF_11
M20 11 IO_L15P_SM13P_11
M19 11 IO_L15N_SM13N_11
P23 11 IO_L16P_SM12P_11
N23 11 IO_L16N_SM12N_11
N22 11 IO_L17P_SM11P_11
N21 11 IO_L17N_SM11N_11
R22 11 IO_L18P_SM10P_11
R23 11 IO_L18N_SM10N_11
P21 11 IO_L19P_SM9P_11
P20 11 IO_L19N_SM9N_11
F24 13 IO_L0P_SM8P_13
F25 13 IO_L0N_SM8N_13
E25 13 IO_L1P_SM7P_13
E26 13 IO_L1N_SM7N_13
G26 13 IO_L2P_SM6P_13
H26 13 IO_L2N_SM6N_13
G24 13 IO_L3P_SM5P_13
G25 13 IO_L3N_SM5N_13
J25 13 IO_L4P_13
J26 13 IO_L4N_VREF_13
H24 13 IO_L5P_SM4P_13
J24 13 IO_L5N_SM4N_13
L24 13 IO_L6P_SM3P_13
L25 13 IO_L6N_SM3N_13
K25 13 IO_L7P_SM2P_13
K26 13 IO_L7N_SM2N_13
M25 13 IO_L8P_CC_SM1P_13
M26 13 IO_L8N_CC_SM1N_13
M24 13 IO_L9P_CC_SM0P_13
N24 13 IO_L9N_CC_SM0N_13
P26 13 IO_L10P_CC_13
N26 13 IO_L10N_CC_13
P25 13 IO_L11P_CC_13
P24 13 IO_L11N_CC_13
R25 13 IO_L12P_VRN_13
R26 13 IO_L12N_VRP_13
T24 13 IO_L13P_13
T25 13 IO_L13N_13
V26 13 IO_L14P_13
U26 13 IO_L14N_VREF_13
U24 13 IO_L15P_13
U25 13 IO_L15N_13
W25 13 IO_L16P_13
W26 13 IO_L16N_13
Y25 13 IO_L17P_13
Y26 13 IO_L17N_13
AB25 13 IO_L18P_13
AA25 13 IO_L18N_13
AC26 13 IO_L19P_13
AB26 13 IO_L19N_13
I'm not sure why the older version allowed this. But the point is the most up to date version of the tools are properly reporting the Error.
@rswathi-12,
Is there a change in device? Check the error message, The tool is complaining about the invalid site for SYSMON site.
--Syed
Hi Syed,
Please find the details taken from both the project files:
Old ISE project file(.ise):
Target device : xc5vlx50t-1ff665
Tool version : ISE 9.2.04i
New ISE project file(.xise):
Tool version : 14.7
I hope there is no change in the target device.
W24     17      IO_L4P_17
U24     13      IO_L15P_13
G20 11 IO_L0P_11
F20 11 IO_L0N_11
E21 11 IO_L1P_11
E20 11 IO_L1N_11
E22 11 IO_L2P_11
E23 11 IO_L2N_11
F22 11 IO_L3P_11
F23 11 IO_L3N_11
G21 11 IO_L4P_11
H21 11 IO_L5P_11
H22 11 IO_L5N_11
J19 11 IO_L6P_11
H19 11 IO_L6N_11
H23 11 IO_L7P_11
J23 11 IO_L7N_11
J21 11 IO_L8P_CC_11
J20 11 IO_L8N_CC_11
K21 11 IO_L9P_CC_11
K20 11 IO_L9N_CC_11
M22 11 IO_L13P_11
M21 11 IO_L13N_11
P19 11 IO_L14P_11
J25 13 IO_L4P_13
T24 13 IO_L13P_13
T25 13 IO_L13N_13
V26 13 IO_L14P_13
U24 13 IO_L15P_13
U25 13 IO_L15N_13
W25 13 IO_L16P_13
W26 13 IO_L16N_13
Y25 13 IO_L17P_13
Y26 13 IO_L17N_13
AB25 13 IO_L18P_13
AA25 13 IO_L18N_13
AC26 13 IO_L19P_13
AB26 13 IO_L19N_13
@rswathi-12,
If your query is addressed then please close this thread by marking the above post which helped as "Accept as solution"
--Syed
@klumsde
Thanks for the clarification. Once the mapping of sysmon pins are done as suggested by the tool the issue is resolved. I too wonder how the older version didn't threw any errors.
