Match types between connected pins
when I get a warning like this:
WARNING: [BD 41-1731] Type mismatch between connected pins: /verandfreqcount_0/onepps(undef) and /onepps(clk)
What's the best way to set the type on verandfreqcount_0/onepps?
Example with both the command line and the createandpackage IP tool?
Re: Match types between connected pins
This is the ipx version of it on the command line, but I was wondering if it's possible after the fact or if there were others.
ipx::infer_bus_interface onepps xilinx.com:signal:clock_rtl:1.0 [ipx::current_core]
ipx::infer_bus_interface highspeedclk xilinx.com:signal:clock_rtl:1.0 [ipx::current_core]
Hi @petersk,
The best way is when you package the IP. In the port definition, just change the type to clk.
Where would you change the port definition to clk?
Sorry, it was already in this thread and I missed it. Simply right click on the port and "Auto infer"...
