Migrate my customized ip to another PC
Issue was solved.
Re: Migrate my customized ip to another PC
Hi @rmirosan,
You can try copying the packaged IP directory contents to the new PC.
Voyager
Voyager
IP integrator? Grab the UG1118
Hi @rmirosan,
