Missing PAD direction for differential clock input in csv pin assignment logfile
in the pin assignment log files (*.txt, *.pad and *.csv) generated from par the direction of the inverted
differential clock input is missing for V6. Please see the fillowing example:
Release 13.2 - par O.61xd (lin64)
*.txt
|Pin Number|Signal Name  |Pin Usage|Pin Name      |Direction|IO Standard|IO Bank Number|
|AH11      |gclk0_p_438  |IOB      |IO_L0P_GC_34  |INPUT    |LVDS_25    |34
|AJ10      |gclk0_n_437  |IOB      |IO_L0N_GC_34  |         |LVDS_25    |34
*.csv
AH11,gclk0_p_438,IOB,IO_L0P_GC_34,INPUT,LVDS_25,34,,,,NONE,,LOCATED,NO,DIFF_TERM,
AJ10,gclk0_n_437,IOB,IO_L0N_GC_34,,LVDS_25,34,,,,,,LOCATED,NO,DIFF_TERM,
*.pad
AH11|gclk0_p_438|IOB|IO_L0P_GC_34|INPUT|LVDS_25|34||||NONE||LOCATED|NO|DIFF_TERM|
AJ10|gclk0_n_437|IOB|IO_L0N_GC_34||LVDS_25|34||||||LOCATED|NO|DIFF_TERM|
Is this a bug ?
For differential clock outputs the direction is reported correctly for both pins.
Sven.
Advisor
Advisor
Re: Missing PAD direction for differential clock input in csv pin assignment logfile
It doesn't seem to be a bug; it's just how the direction is shown in PAD report for diff clock. There is a related discussion on DIFF_TERM display.
Evgeni
Advisor
Advisor
