mheraswavenet
Missing blocks
I'm designing a complex system in Spartan7 with Verilog, in which all blocks are present except one after running implementation. I've also isolated the block in a new design, but it is also missed. Simulation runs correctly. Any idea?
Thank for your help.
Top module:
`timescale 1ns / 1ps
// Company:
// Engineer:
// Create Date: 02.10.2019 17:47:42
// Design Name:
// Module Name: kkLina
// Project Name:
// Target Devices:
// Tool Versions:
// Description:
// Dependencies:
// Revision:
// Revision 0.01 - File Created
// Additional Comments:
module kkLina(
input dIn,
input Clk,
input Enab,
output Out
Receptor rxItem(.DataIn(dIn), .ClkModem(Clk), .Enable(Enab), .Valid(Out));
endmodule
Receptor module:
`timescale 1us / 100ns
// Company:
// Engineer:
// Create Date: 01.10.2019 11:48:52
// Design Name:
// Module Name: Receptor
// Project Name:
// Target Devices:
// Tool Versions:
// Description:
// Dependencies:
// Revision:
module Receptor(
input DataIn,
input ClkModem,
input Enable,
output reg Valid
parameter eIni = 'b00, eEnabled = 'b01, eFinal = 'b10;
reg [1:0] estado;
reg [`NumBitsPattern - 1:0] valor;
// initial
// Valid = 0;
always @(posedge Enable or negedge ClkModem or posedge ClkModem) begin
if ((Enable == 0) && (ClkModem == 1)) begin
Valid <= 0;
estado <= eIni;
valor <= 'b000000;
end // if ((Enable == 0) && (ClkModem == 1)) begin
else begin
case (estado)
eIni: begin
if ((Enable == 1) && (ClkModem == 1))
estado <= eEnabled;
end // eIni: begin
eEnabled: begin
if ((Enable == 1) && (ClkModem == 0)) begin
valor = {valor, DataIn};
if (valor == `Pattern) begin
estado <= eFinal;
Valid <= 1;
end // if (valor == 'b10001) begin
end // if ((Enable == 1) && (ClkModem == 0)) begin
end // eEnabled: begin
eFinal: ;
default: begin
Valid <= 0;
estado <= eFinal;
end // default: begin
endcase // case (estado)
end // else begin
end // always @(posedge Enable or negedge ClkModem or posedge ClkModem) begin
endmodule // module Receptor();
module Receptor_testbench();
reg dIn;
reg clk;
reg enab;
wire valid;
Receptor testReceptor(.DataIn(dIn), .ClkModem(clk), .Enable(enab), .Valid(valid));
initial begin
clk=0;
enab = 0;
dIn = 0;
end // initial begin
initial begin: clkLoop
forever #5 clk=~clk;
end // initial begin: clkLoop
initial begin
#11 enab = 1;
#15 dIn = 1;
#10 dIn = 0;
#30 dIn = 1;
#10 dIn = 0;
#20 enab = 0;
#100 disable clkLoop;
#1 $finish;
end
endmodule // module Receptor_testbench();
I think your Valid signal is optimized to 0 as shown in the diagram, that could because of your comparison valor==`Pattern, I can't see that constant defined
rshekhaw
Hi @mheraswavenet ,
Try to apply DONT_TOUCH attribute in RTL or module block which is optimized and check whether it helps. For information on DONT_TOUCH check page no.49 of below link:
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2019_1/ug901-vivado-synthesis.pdf
Raj
mheraswavenet
Hi, Raj.
It doesn't work. Please, look at attached the schema it generates.
Kind regards,
Manuel Heras
hemangd
Hi @mheraswavenet
Kindly modify your RTL becuase your output port "Valid" only connected with constants as shown in the Receptor RTL.
And input port "Datain" is not provided with the proper connection. Check it in elaborated design.
I have applied dont_touch on registers which were removed due to it's no used (code attached). Now it shows as shown below but you will still have to modify your Receptor RTL for Datain port and Valid port.
hemangd
mheraswavenet
Hi, hemanged
I've solved the problem. I don't know very well where it was, but it seems that it was related to the way in which the clocks were managed. Additionally, looking to your schematic I can note that the otuput port (Valid) still appears grounded.
Kind regards.
