Visitor net.worker
Modification of SmartXplorer default strategies
Hello all,
I am trying to add the "-detail" MAP switch to SmartXplorer (SX) runs.
Since -mo will replace all options, my idea was to modify the default strategies (.xds) found in the directory:
/ISE_DS/ISE/spartan6/data/smartxplorer/
by inserting
<property name = "Map:Generate Detailed MAP Report"
value = "true" />
This works when I apply that strategy manually to my project in ISE.
However, SX runs don't seem to use the changed file.
In the /runXY dirs, the .xds file used for the run is found. This file does not contain the new key-value pair. Also, I noted that the "Version" in the header says 13.2 (my used ISE version), but the strategy files in /ISE_DS/ISE/spartan6/data/smartxplorer/ have 12.1, and others.
Now my question,
does SX use the files located in the ISE install at all, or are the strategies hard compiled into the SX binary? What are the files for then?
If so, how can I add the switch? Would I have to make copies of the strategies elsewhere and feed them one by one to SX?
Florian
Community Manager
Community Manager
Re: Modification of SmartXplorer default strategies
Yes. You are right. These strategies are provided in the install area for users to know on what options have been used.
Sx binary doesnt pick them.
The feature to append an option is requested and is in a roadmap. For now, I would recommend creating a custom stategy defined including all the strategies in one single file. Please see the last section of the following user guide.
Hope this helps.
http://www.xilinx.com/support/documentation/user_guides/ug688.pdf
Community Manager
Community Manager
Hope this helps.
Visitor net.worker
Okay, I see.
Is there a way I can dump all the default strategies' switch values in the same style as seen in the UG?
As I understand from the UG, this is what I would pass to the SX command line, and not an .xds file.
Background:
The .xds files use the XML-style format which does not print out CLI switches. I could look up all the settings and translate them, but this would be a very manual and error-prone task.
Florian
Community Manager
Community Manager
You can use a custom strategy file and use all the options in there. You have to use -sf switch.
the strategy file can be a text file.
Visitor net.worker
Yes, this is what I want to do. Create a file like this, as in the UG:
"spartan3e":
{"name": "My_Strat_1",
"map": " -timing -ol high -xe n -register_duplication on -logic_opt on ",
"par": " -ol high"},
{"name": "My_Strat_2",
"map": " -timing -ol high -t 9",
"par": " -ol high -t 9"},
But now I wonder, where do I find the exact switches for each of the original strategies like MapRegDup... to copy them into one file?
Florian
One way that might be a little better than manual translation from .xds.
Select menu Project > Design Goals & Strategies... Browse to the default smartxplorer .xds file and enter it to the Strategy File field. Apply it to the current project.
Then open implementation properties dialog box. You'll see the associated switches are locked.
Newbie sumanka
User  "list all strategies" option to get a list of all strategy files
Example :  To get a list of spartan6 strategies use
smartxplorer -p xc6slx75t-fgg484-2 -la
Community Manager
Community Manager
-la will help.You could try this
Visitor net.worker
Thanks, -la was absolutely what I was looking for.
For reference, this is the strategy file I created, I'll give it a try later:
"spartan6":
{"name": "MapRunTime",
"map": " -timing -ol high -xe n -register_duplication on -logic_opt on -detail",
{"name": "MapLogicOpt",
"map": " -ol high -xe n -logic_opt on -t 2 -w -detail",
"par": " -ol high -xe n -logic_opt on -t 2 -w"},
{"name": "MapGlobOptIOReg",
"map": " -ol high -global_opt speed -pr b -w -detail",
"par": " -ol high -xe n"},
{"name": "MapRegDup",
"map": " -ol high -xe n -register_duplication on -w -detail",
{"name": "MapExtraEffortIOReg",
"map": " -ol high -xe n -pr b -t 7 -w -detail",
{"name": "MapLogOptRegDup",
"map": " -ol high -xe n -logic_opt on -register_duplication on -t 2 -w -detail",
{"name": "MapExtraEffort2",
"map": " -ol high -xe n -t 3 -w -detail",
Visitor net.worker
As I can't edit the last post, here the full file again with some corrections:
"spartan6":
{"name": "MapRunTimeD",
"map": " -ol high -w -detail",
{"name": "MapLogicOptD",
{"name": "MapGlobOptIORegD",
{"name": "MapRegDupD",
{"name": "MapExtraEffortIORegD",
{"name": "MapLogOptRegDupD",
{"name": "MapExtraEffort2D",
I've tried this file using the -sf switch, and it works! The detailed map report is generated every time.
Excellent tips here, thank you all again.
I guess the approach to keep this file static is fine, or are there frequent updates to the builtin SX strategies? I woudn't think so...
Now I might start playing around with those strategies a little!
