Multipass Place and Route
Hi all,
I'm working on  a large desing  and I'm having some problems making it respect timing constraint.
So I tried MultiPass Place and Route with just 2 iterations
The first one ended with an error saying that was not possible to completely route all the design ... the second one instead routed the design respecting the constraint.
Attached you'll find the last part of the report it says that PAR failed ... but one of the iterations succeded!!!
How can I use it to generate my bitstream?!?!?
I tried to use the .ncd file produced as imput for a guided par ... but at the end it didn't respect the timing constraint!
How it is possible??
I'm using Xilinx ISE8.2sp3
Placement: Completed - No errors found.
Routing: Completed - No errors found.
Timing: Completed - No errors found.
Number of error messages: 0
Number of warning messages: 17
Number of info messages: 3
Writing design to file C:/Progetti/ICS8550-L50/G11464-002/ICS_8550/mppr_result.dir/H_H_2.ncd
PAR done!
Process "Place & Route" failed
Professor
Professor
Re: Multipass Place and Route
You could try turning off Timing Driven packing & placement, but usually that option
helps when trying to place and route large designs that are having trouble making
timing.
Other things to try:
If you still have the placement that "met timing" but also "failed" perhaps you can
open it in FPGA editor.  Often just using the placement for non-fabric resources
like block rams and multipliers/DSP units can help P&R to give you a usable
result.
Upgrade to a newer version of ISE.  You can have multiple versions on the
same system, so if there are issues with the newer tools you can easily go
back to 8.2.  Also if you use the latest version of the tools you may get
better response from Xiinx when you find bugs.
Look through the post P&R timing report for a pass that doesn't meet timing
and see if you can fix the timing problems by relaxing some constraints or
changing the design. You may also get help by playing with synthesis, translate
and map options like register balancing, register replication, shutting
off resource sharing, etc.
Gabor
-- Gabor
Professor
Professor
As a workaround, you should be able to get the same results from a single-pass
place and route if you use the cost table entry from the multipass P&R that
gave your desired results.  For example if your starting cost table was 1
(default) and the second pass (using table entry 2) completed and
met timing, you could just change the starting cost table entry to 2 in
your P&R settings and run standard place & route instead.
Gabor
-- Gabor
that's what I thought too... but I tried with a single pass place and route setting the cost table entry to 2 and ... it didn't work.
The routing was different from what I got with multipass, timing constraint were not met.
I'm pretty confused.
Professor
Professor
I thought that issue was fixed in 8.2, apparently not.  You can always do a "manual multipass P&R"
as a workaround, changing the starting cost table entry for each pass manually and running
the standard P&R.  When you ran the multipass P&R were you using "Timing driven packing and
placement" in your mapping options?  This option effectively causes multi-pass P&R to
do just re-entrant routing since the placement is done by the mapper and that is not
re-run in the loop.
-- Gabor
Yes I did use "Timing driven packing and placement". So if I understand well if it is re-entrant ... the placement that MPRR calls 2 is not the one obtained with cost table entry to 2 but it is also dependent on the first placement.
So what can I do? Maybe deactivating Timing driven packing I can test if multipass is able to reach a working placement.
Or as you suggest run multiple PR by changing manually the starting cost table.
That's very annoying in any case ...
Professor
Professor
timing.
result.
Gabor
-- Gabor
Finally I turned off Timing Driven packing & placement and run Multi Pass Place & Route.
It met the timing constraint at the second iteration .. then I run a Normal Place & Route setting the Cost Table entry to 2, and it worked.
Anyway everytime I change also little particulars I have to face with this problems Timing Constraints, Guide Map and PAR helped a little bit in the past  ... but   it doesn't work always as expected.
Unfortunately I can't relax the constraint and I can't update to the newer ISE version.
