caryan
New Place error in Vivado 2015.3
We have a design where we xor two clocks together - one on a BUFG and one on a BUFR - to try and measure their relative phase.  This worked fine in 2015.1 but now fails in 2015.3 with `[Place 30-174] Unroutable Placement!`. In particular:
* Artix 7 part
* one clock comes into clock region X1Y3 into an MMCM and then onto a BUFG
* another clock comes into clock region X1Y1 through a IBUFDS and BUFR
* Place now fails with
[Place 30-174] Unroutable Placement! The following clock source components are placed too far from each other.  These clocks drive common load instances. This requires them to be placed in a relative way such that both clocks can drive the common load instances. Please refer to the clocking user guide for more details on which clock regions these clock sources can drive.
	WFOutputA/clkout_buf_inst (BUFR.O) is provisionally placed by clockplacer on BUFR_X1Y4
	 SYSCLK_MMCM_inst/inst/mmcm_adv_inst (MMCME2_ADV.CLKOUT0) is provisionally placed by clockplacer on MMCME2_ADV_X1Y3
	 WFOutputA/clk_phase/phase_sync[0]_i_1 (LUT2.I0) cannot be placed
	 WFOutputA/clk_phase/phase_sync[0]_i_1 (LUT2.I1) cannot be placed
	The above error could possibly be related to other connected instances. Following is a list of
	all the related clock rules and their respective instances.
	Clock Rule: rule_bufh_bufr_ramb
	Status: PASS
	Rule Description: Reginal buffers in the same clock region must drive a total number of brams less
	than the capacity of the region
	Clock Rule: rule_iotile_bufr
	Status: PASS
	Rule Description: An IO driving a BUFR must both be placed in the same clock region
	 WFOutputA/ibufds_clk_inst (IBUFDS.O) is locked to IOB_X1Y74
	 WFOutputA/clkout_buf_inst (BUFR.I) is provisionally placed by clockplacer on BUFR_X1Y4
	Clock Rule: rule_mmcm_bufg
	Status: PASS
	Rule Description: An MMCM driving a BUFG must be placed on the same half side (top/bottom) of the device
	 SYSCLK_MMCM_inst/inst/mmcm_adv_inst (MMCME2_ADV.CLKFBOUT) is provisionally placed by clockplacer on MMCME2_ADV_X1Y3
	 SYSCLK_MMCM_inst/inst/clkf_buf (BUFG.I) is provisionally placed by clockplacer on BUFGCTRL_X0Y27
	Clock Rule: rule_gclkio_mmcm_1load
	Status: PASS
	Rule Description: An IOB driving a single MMCM must both be in the same clock region if CLOCK_DEDICATED_ROUTE=BACKBONE
	is NOT set
	 SYSCLK_MMCM_inst/inst/clkin1_ibufgds (IBUFDS.O) is locked to IOB_X1Y176
	 and SYSCLK_MMCM_inst/inst/mmcm_adv_inst (MMCME2_ADV.CLKIN1) is provisionally placed by clockplacer on MMCME2_ADV_X1Y3
The placer is putting everything where I expect but it almost seems that it is missing the BUFG and seeing the driver as the direct MMCM output
bwade
You are seeing this regression due to a new 2015.3 logic_opt optimization that pushes non-sequential BUFG loads to the front side of the BUFG. This AR is not an exact match for your issue, but the same param work around should fix your problem by restoring the 2015.2 behavior.
http://www.xilinx.com/support/answers/66086.html
There have been multipe CRs related to this optimizaton and there are bugfixes coming in 2016.1 so that this optimization is done more approprately.
Bret
caryan
A couple quick updates:
1. Vivado 2015.4 has the same issue.
2. Fixing the BUFG at a random BUFGCTRL in the X1Y3 clock region
set_property LOC BUFGCTRL_X0Y24 [get_cells sys_clk_mmcm_inst/inst/clkout2_buf]
fixes this issue.  However, it always seems something is wrong when I have to manually locate something.
vemulad
Hi @caryan
What is the site at which the BUFG instance is placed in 2015.1 passing design?
Is it possible for you to share post opt.dcp file for investigation?
Deepika.
Deepika.
caryan
@vemulad thanks for having a look.  I've put together a minimal example design showing succesful PAR in Vivado 2015.1 and failing in 2015.3 The 2015.3 project is created by opening the 2015.1 version, upgrading the IP and rerunning synthesis and implementation up to the place error above.
bwade
Bret
vemulad
Hi @caryan
Just to add to Bret's comments,
I ran the test case which you have shared in 2016.1 internal build where it completed succesfully.
Deepika.
Deepika.
caryan
Thanks for the updates folks.  Look forward to 2016.1
