Observer hcuongvn
Not available when DLL_FREQUENCY_MODE is set to HIGH
I'm using ISE and EDK 10.1. I try to build my project in ISE and EDK. But I got this error:
ERROR:LIT:141: - CLK90, CLK270, CLK2X and CLK2X180 of DCM symbol "microblaze_ins/clock_generator_0/clock_generator_0/Using_DCM1.DCM1_INST/DCM_INST/Using_Virtex.DCM_INST" (output signal=microblaze_ins/clock_generator_0/clock_generator_0/DCM1_CLK_OUT<0>) is not available when DLL_FREQUENCY_MODE is set to HIGH.
I used clock generator to generate 3 clocks 200Mhz from input clock 125Mhz.
I searched some topics in this forum. But It's not show the way to fix this error.
Can you help me?
Thank you!
Scholar austin
Re: Not available when DLL_FREQUENCY_MODE is set to HIGH
What device?
Have you looked at the user's guide for the clocking resources?
I had to instatiate another advanced DCM block when I needed to do some clocking outside of the MicroBlaze (I could not just 'add' options to the existing DCM, because it was alread using all of the resources for the MicroBlaze-my poblem was not a mode issue).  You might try adding another DCM to your project.
This was back int eh Virtex 5 days, so I haven't used the V6 or 7-sereis clocking lately in EDK (and I have not used S6, either).
Austin Lesea
Principal Engineer
Xilinx San Jose
Scholar austin
OK,
You have to have the frequency mode set to high to operate at this frequency.
You do not get the indicated signals when in this mode (on this part, which you did not tell us which one it was).
So, what about:  you can not do this do you not understand?
Use a lower frequency, or use a part that supports the operation of those signals.
Or, use another DCM with fixed phase shift to get the signals you require (if the part supports it).
Austin Lesea
Principal Engineer
Xilinx San Jose
Observer hcuongvn
OK, I got it!
Now, I have to supply higher frequency clock input or change the output clock lower frequency, right?
But I saw some MHS code in this forum. I saw they supplied 125Mhz to generate 200Mhz same as me! I followed their code and I got error!
Scholar austin
What device?
Austin Lesea
Principal Engineer
Xilinx San Jose
Observer hcuongvn
I'm using Microblaze processor Virtex 2 Pro.
Ok, I'll try to follow your way!
Thank you!
Scholar austin
"Note that CLK2X and CLK2X180 are not available in
high-frequency mode."
http://www.xilinx.com/support/documentation/data_sheets/ds083.pdf
page 52
This is from the data sheet, so you will not be able to use the V2 Pro the way you want to.
You will have to do it the way I suggest, with more DCM's and using fixed phase shifts to get the outputs at the relationships you want.
Austin Lesea
Principal Engineer
Xilinx San Jose
Observer hcuongvn
Thank you, austin!
