Opt 31-67 with custom IP with AXI Stream bus
I wrote a small custom AXI4-Strean Master IP (no wizard) with the following I/O ports declarations and register assignments:
module RawToAXIStream
        input wire data_clk,
        input wire [31:0] data_in,
        // AXIS Interface
        input wire clk,
        output wire [31:0] tdata,
        output wire [3:0] tstrb,
        output wire [3:0] tkeep,
        output wire tlast,
        output wire tvalid,
        input wire tready
    reg tvalid_reg;
    reg [31:0] tdata_reg;
    reg [3:0] tkeep_reg;
    reg [3:0] tstrb_reg;
    reg tlast_reg;
    reg [2:0] state;
    reg data_sent;
    assign tdata = tdata_reg;
    assign tvalid = tvalid_reg;
    assign tlast = tlast_reg;
    assign tkeep = tkeep_reg;
    assign tstrb = tstrb_reg;
    // implementation not shown
endmodule
and I want to interface it with an AXI DMA as shown here:
However, on validating the design, Vivado claims that S_AXIS_S2MM interface is not connected:
 [xilinx.com:ip:axi_dma:7.1-11] /axi_dma_0
  S_AXIS_S2MM interface is unconnected
in fact the implementation fails with this error:
[Opt 31-67] Problem: A LUT5 cell in the design is missing a connection on input pin I1, which is used by the LUT equation. This pin has either been left unconnected in the design or the connection was removed due to the trimming of unused logic. The LUT cell name is: design_1_i/axi_dma_0/U0/I_PRMRY_DATAMOVER/GEN_S2MM_FULL.I_S2MM_FULL_WRAPPER/ENABLE_AXIS_SKID.I_S2MM_STRM_SKID_BUF/sig_m_valid_dup_i_1__1.
The same happens if I try to connect my IP to a AXI4-Stream Data FIFO as shown here:Screenshot_2019-02-01_18-29-25.png
[Opt 31-67] Problem: A LUT4 cell in the design is missing a connection on input pin I3, which is used by the LUT equation. This pin has either been left unconnected in the design or the connection was removed due to the trimming of unused logic. The LUT cell name is: design_1_i/axis_data_fifo_0/inst/gen_fifo.xpm_fifo_axis_inst/xpm_fifo_base_inst/xpm_fifo_rst_inst/count_value_i[3]_i_2.
It seems that Vivado does not recognize the connection between my custom Master IP and the slave.
Do the port must be declared differently to match the connections if it's done without a wizard ?
What am I missing ?
Thanks & Regards,
simozz
Re: Opt 31-67 with custom IP with AXI Stream bus
@simozz
Check "common design errors" in below link:
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_3/ug904-vivado-implementation.pdf#page=52
--Syed
Hi @simozz.
The messaging would indicate that there is a connectivty problem with the LUT in question. I would suggest opening the synthesized design, and following the I1 pin from the message. What is driving this? If undriven, then this should be connected. I will list a good resource for debugging opt_design issues.
https://www.xilinx.com/support/answers/58616.html
Hi @marcb,
What is the main cause of this problem and how to prevent it ?
simozz
@simozz
--Syed
Hello @syedz
That links seems to be more useful.
In fact, initializing the registers solved the problem.
