10-02-2020 04:53 AM
Hi everyone,
I am working with Vivado 2018.2 and using JESD204_PHY and JESD204 block in my block design. I see that the tx output port of my top module do not appear in the implemented design. I did not specify the constraints in the .xdc file. I see in this post https://forums.xilinx.com/t5/Implementation/Leave-top-level-ports-unplaced/m-p/670336/thread-id/14198
that not specifying constraints for a top module port should not be a problem as some package pin is assigned.
I also refered to a similar post to mine which is as follows but that did not help
Can someone suggest what can be done?
Thanks in advance,
-Chandrasekhar DVS
10-11-2020 07:03 PM
Is the output port of the JESD block directly connected to the top level output port?
Do you see package pin constraint for the output port in IP level xdc?
