Visitor gillesb
PAR Taking forever
Hey
I am implementing a design vor Virtex 6 on ISE 12.4 (please do not tell me to upgrade, licenese issues...).
My most recent design seems to have problems implementing.
The PAR has been running over the whole weekend+1day and still hasnt finished. It seems stuck at:
"Phase  4  : 122774 unrouted; (Setup:2901102, Hold:61052, Component Switching Limit:0)     REAL time: 10 mins"
I enabled multi-threading with up to 4 cores. And "par.exe" is using 50% of my 8-core-CPU right now. So it seems there are some massive calculations still being done.
My question:
If the process-consumption is 100% of the allowed core-usage, is it guaranteed to move forward or could it be stuck in a never ending loop?
FYI: We are using a floating licenese and in the licenese manager it says "Licenses in use" is 0/1 everywhere. Is this an indicator that it is not moving on anymore?
Thank you,
Gilles B
Community Manager
Community Manager
Re: PAR Taking forever
From your observation, this looks stuck.
From the log. unusually high hold time violation  is seen. Can you try without using any timing constraints?
This can be  caused by sub-optimal clock structure which brings high clock skew. You can check in FPGA Editor or PlanAhead to see how the clock net(s) driving the source and destination is(are) connected. Following are some scenarios that may cause this issue.
  1. The clock net that drives the source and destination does not go through a BUFG
  2. The source clock net goes through a BUFG but the destination clock doesn't
  3. BUFG cascading on the clock net(s)
  4. Other structures that bring high clock skew
Visitor gillesb
Finally finished!!
Total REAL time to PAR completion: 3 days 18 hrs 24 mins 34 secs
Total CPU time to PAR completion (all processors): 15 hrs 8 mins 15 secs
but both timing constraints not met :-(
but thats usually the case... still performs nicely.
whats the easiest way to make sure the clokc distribution isnt the problem.
because consumption is about 18%
though DSP slices is about 78%...
Gilles B
Community Manager
Community Manager
Thanks for the update. Please analyze your clocking structure to make sure that this is not the root cause.
Historian
Historian
But....
In 3 days and 18 hours, it only managed to consume 15hrs of CPU time (on all cores). This is a pretty large indication that you do not have enough RAM on your computer, and it is spending all its time swapping.
While it is running (next time) look at your memory utilization, and you will probably be able to confirm this. If so, adding more RAM will likely have a HUGE impact on your placement time - probably bringing it down to (around) 15 hours.
Avrum
Teacher rcingham
If it's doing A LOT of swapping, you should be able to hear the disk drives. That happened to me once (many years ago), and when the man from IT heard the sound it was making, he put more memory in straight away!
"If it don't work in simulation, it won't work on the board."
Historian
Historian
@gillesb wrote:
Finally finished!!
Gilles B
I wonder if your design has a LOT of combinatorial logic.
Look through your reports for number of logic levels. What's the worst value, and what is a more-common value?
