Newbie gnk_envent
PAR report
I am using ISE 12.1 and getting the following PAR report after place and route .
Its not showing any of setup values, but shows only in final stage as follows:
Phase  5  : 0 unrouted; (Setup:273, Hold:486295, Component Switching Limit:0)     REAL time: 4 mins 32 secs
Phase  6  : 0 unrouted; (Setup:273, Hold:486295, Component Switching Limit:0)     REAL time: 4 mins 35 secs
Phase  7  : 0 unrouted; (Setup:0, Hold:486295, Component Switching Limit:0)     REAL time: 5 mins 9 secs
Phase  8  : 0 unrouted; (Setup:0, Hold:486295, Component Switching Limit:0)     REAL time: 5 mins 9 secs
Phase  9  : 0 unrouted; (Setup:0, Hold:486295, Component Switching Limit:0)     REAL time: 5 mins 10 secs
Phase 10  : 0 unrouted; (Setup:0, Hold:0, Component Switching Limit:0)     REAL time: 5 mins 33 secs
Phase 11  : 0 unrouted; (Setup:3867, Hold:0, Component Switching Limit:0)     REAL time: 5 mins 43 secs
How come It will show setup value in final phase instead of earliey phases of PAR report...I never seen this kind of report in earlier versions  and is happening with ISE 12.1
Do I need to (consider) react for this report to reduce the design's " timing score"? Looking for clarifiction. Thanks in advance
Anonymous
Not applicable
Re: PAR report
I would open up a webcase to see why  timing score regressed after it met timing.
Re: PAR report
The router does a lot of pin-swapping as it rips up and re-routes the design and pin delays can change as that occurs. It doesn't immediately recalculate the new pin delays to save run-time so it is temporarily working with old pin delay information. I think what happened in your case was that the router met timing in phase 10, updated the pin delays and then reported a "new" timing violation in phase 11.
That said I don't remember seeing a swing as large as this. I also think based on when this occurred that the hold time router must be involved. It's not clear from your post whether phase 11 was the final router iteration. Did it quit with that timing error?
