PK_FACTORY failed to create PK_FRAG
Has anyone run into this error during MAP?
Re: PK_FACTORY failed to create PK_FRAG
FATAL_ERROR:Pack:pkibangm.c:2746:1.87 - PK_FACTORY failed to create PK_FRAG
U112/U3 of type LUT. Process will terminate. For technical support on this
issue, please open a WebCase with this project attached at
http://www.xilinx.com/support.
This is still a problem, and apparently I can't open a webcase?
Anonymous
Not applicable
I get the same error when I remove synchronous resets from a section of code where testpoints are driven.  I don't have any answers for you, but at least you know that someone else has this issue.  I've opened a web case today.  I'll reply back with what I learn.
What device and what tool revision? The closest match I can find in the CR database for this error involved use of the "-k 7" option (deprecated in recent tool revisions) on older architectures. The CR was left unfixed because this wide-gate option was seen as an edge case for the architectures involved.
