ParHelpers:360 - Design is not completely routed.
I am using a DDR2 core in a Spartan6 with ISE 14.7  and get this error during PAR:
WARNING:ParHelpers:360 - Design is not completely routed.
DDR2_inst/memc5_wrapper_inst/memc5_mcb_raw_wrapper_inst/ioi_drp_clk_c
When I open the .ncd file, I can see the unrouted net, but how do I fix this?
John
@jvincent12
Can you show the schematic (source and load) of failing net?
--Syed
Here is a snippet of the mcb_raw_wrapper.vhd file
samc_0: MCB
GENERIC MAP
( PORT_CONFIG => C_PORT_CONFIG,
MEM_WIDTH => C_NUM_DQ_PINS ,
MEM_TYPE => C_MEM_TYPE ,
MEM_BURST_LEN => C_MEM_BURST_LEN ,
MEM_ADDR_ORDER => C_MEM_ADDR_ORDER,
MEM_CAS_LATENCY => C_MEM_CAS_LATENCY,
MEM_DDR3_CAS_LATENCY => C_MEM_DDR3_CAS_LATENCY ,
MEM_DDR2_WRT_RECOVERY => C_MEM_DDR2_WRT_RECOVERY ,
MEM_DDR3_WRT_RECOVERY => C_MEM_DDR3_WRT_RECOVERY ,
MEM_MOBILE_PA_SR => C_MEM_MOBILE_PA_SR ,
MEM_DDR1_2_ODS => C_MEM_DDR1_2_ODS ,
MEM_DDR3_ODS => C_MEM_DDR3_ODS ,
MEM_DDR2_RTT => C_MEM_DDR2_RTT ,
MEM_DDR3_RTT => C_MEM_DDR3_RTT ,
MEM_DDR3_ADD_LATENCY => C_MEM_DDR3_ADD_LATENCY ,
MEM_DDR2_ADD_LATENCY => C_MEM_DDR2_ADD_LATENCY ,
MEM_MOBILE_TC_SR => C_MEM_MOBILE_TC_SR ,
MEM_MDDR_ODS => C_MEM_MDDR_ODS ,
MEM_DDR2_DIFF_DQS_EN => C_MEM_DDR2_DIFF_DQS_EN ,
MEM_DDR2_3_PA_SR => C_MEM_DDR2_3_PA_SR ,
MEM_DDR3_CAS_WR_LATENCY => C_MEM_DDR3_CAS_WR_LATENCY,
MEM_DDR3_AUTO_SR => C_MEM_DDR3_AUTO_SR ,
MEM_DDR2_3_HIGH_TEMP_SR => C_MEM_DDR2_3_HIGH_TEMP_SR,
MEM_DDR3_DYN_WRT_ODT => C_MEM_DDR3_DYN_WRT_ODT ,
MEM_RA_SIZE => C_MEM_ADDR_WIDTH ,
MEM_BA_SIZE => C_MEM_BANKADDR_WIDTH ,
MEM_CA_SIZE => C_MEM_NUM_COL_BITS ,
MEM_RAS_VAL => MEM_RAS_VAL ,
MEM_RCD_VAL => MEM_RCD_VAL ,
MEM_REFI_VAL => MEM_REFI_VAL ,
MEM_RFC_VAL => MEM_RFC_VAL ,
MEM_RP_VAL => MEM_RP_VAL ,
MEM_WR_VAL => MEM_WR_VAL ,
MEM_RTP_VAL => MEM_RTP_VAL ,
MEM_WTR_VAL => MEM_WTR_VAL ,
CAL_BYPASS => C_MC_CALIB_BYPASS,
CAL_RA => C_MC_CALIBRATION_RA,
CAL_BA => C_MC_CALIBRATION_BA ,
CAL_CA => C_MC_CALIBRATION_CA,
CAL_CLK_DIV => C_MC_CALIBRATION_CLK_DIV,
CAL_DELAY => C_MC_CALIBRATION_DELAY,
-- CAL_CALIBRATION_MODE=> C_MC_CALIBRATION_MODE,
ARB_NUM_TIME_SLOTS => C_ARB_NUM_TIME_SLOTS,
ARB_TIME_SLOT_0 => C_ARB_TIME_SLOT_0,
ARB_TIME_SLOT_1 => C_ARB_TIME_SLOT_1,
ARB_TIME_SLOT_2 => C_ARB_TIME_SLOT_2,
ARB_TIME_SLOT_3 => C_ARB_TIME_SLOT_3,
ARB_TIME_SLOT_4 => C_ARB_TIME_SLOT_4,
ARB_TIME_SLOT_5 => C_ARB_TIME_SLOT_5,
ARB_TIME_SLOT_6 => C_ARB_TIME_SLOT_6,
ARB_TIME_SLOT_7 => C_ARB_TIME_SLOT_7,
ARB_TIME_SLOT_8 => C_ARB_TIME_SLOT_8,
ARB_TIME_SLOT_9 => C_ARB_TIME_SLOT_9,
ARB_TIME_SLOT_10 => C_ARB_TIME_SLOT_10,
ARB_TIME_SLOT_11 => C_ARB_TIME_SLOT_11
) PORT MAP
-- CALIBRATION DRP interface
IOIDRPCLK => ioi_drp_clk , -- output of the MCB module
IOIDRPADDR => ioi_drp_addr ,
IOIDRPSDO => ioi_drp_sdo ,
IOIDRPSDI => ioi_drp_sdi ,
IOIDRPCS => ioi_drp_cs ,
IOIDRPADD => ioi_drp_add ,
IOIDRPBROADCAST => ioi_drp_broadcast ,
IOIDRPTRAIN => ioi_drp_train ,
IOIDRPUPDATE => ioi_drp_update ,
-- THERE ARE 22 IODRP2_MCB's instantiated in the design...
iodrp2_DQ_14 : IODRP2_MCB
GENERIC MAP (
DATA_RATE => C_DQ_IODRP2_DATA_RATE,
IDELAY_VALUE => DQ14_TAP_DELAY_VAL,
MCB_ADDRESS => 7,
ODELAY_VALUE => 0,
SERDES_MODE => C_DQ_IODRP2_SERDES_MODE_MASTER,
SIM_TAPDELAY_VALUE => 10
PORT MAP (
AUXSDO => aux_sdi_out_14,
DATAOUT => open,
DATAOUT2 => open,
DOUT => ioi_dq(14),
DQSOUTN => open,
DQSOUTP => in_dq(14),
SDO => open,
TOUT => t_dq(14),
ADD => ioi_drp_add,
AUXADDR => ioi_drp_addr,
AUXSDOIN => aux_sdi_out_15,
BKST => ioi_drp_broadcast,
CLK => ioi_drp_clk, -- input to the iodrp2 module
CS => ioi_drp_cs,
IDATAIN => in_pre_dq(14),
IOCLK0 => ioclk90,
IOCLK1 => '0',
MEMUPDATE => ioi_drp_update,
ODATAIN => dq_oq(14),
SDI => ioi_drp_sdo,
T => dq_tq(14)
This is not the info that we need for debug the issue.
The FPGA Editor screenshot dosen't show what the startpoint and the endpoint of the unrouted net are.
You can check the net in the technology schematic in ISE or the schematic in Planhead.
The Schematic will tell you clearly what the startpoint and endpoint are.
And that would help to analyze why the net is unroutable.
-vivian
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
