ipg
Pin Assingments in Example Designs
I have got a general question. I opened an auto-generated HDMI example design for the ZCU106 board.
Now my question: Where is the pin location assignment for e.g. the HDMI_TX_DAT_P_OUT* pins defined?
So, where is the definition, that HDMI_TX_DAT_P_OUT[0] is mapped to pin AN6? I could not find it...
Thanks for clarification!
Best regards,
ipg
bruce_karaffa
This should be in an xdc file.  Look in your hierarchy   Sources=>Constraints=>constrs_1 and see what is in there.
ipg
Hi, this is where I also assumed the relevant data, but it is not there. There are 3 xdc files:
1) AudioGen.xdc
# Copyright (c) 2014 Xilinx, Inc.  All rights reserved.
# Xilinx, Inc.
# XILINX IS PROVIDING THIS DESIGN, CODE, OR INFORMATION "AS IS" AS A
# COURTESY TO YOU.  BY PROVIDING THIS DESIGN, CODE, OR INFORMATION AS
# ONE POSSIBLE   IMPLEMENTATION OF THIS FEATURE, APPLICATION OR
# STANDARD, XILINX IS MAKING NO REPRESENTATION THAT THIS IMPLEMENTATION
# IS FREE FROM ANY CLAIMS OF INFRINGEMENT, AND YOU ARE RESPONSIBLE
# FOR OBTAINING ANY RIGHTS YOU MAY REQUIRE FOR YOUR IMPLEMENTATION.
# XILINX EXPRESSLY DISCLAIMS ANY WARRANTY WHATSOEVER WITH RESPECT TO
# THE ADEQUACY OF THE IMPLEMENTATION, INCLUDING BUT NOT LIMITED TO
# ANY WARRANTIES OR REPRESENTATIONS THAT THIS IMPLEMENTATION IS FREE
# FROM CLAIMS OF INFRINGEMENT, IMPLIED WARRANTIES OF MERCHANTABILITY
# AND FITNESS FOR A PARTICULAR PURPOSE.
# This file contains the clock domain crossing false paths for the
# audio generator.
# MODIFICATION HISTORY:
# Ver   Who Date         Changes
# 1.00  hf  2014/10/21   First release
# 1.02  RHe 2014/12/08   Updated constraints for the added clock domain
#                        crossing logic.
# 1.04  RHe 2015/01/15   Added missing constraints AXI lite to AXI streaming
# 1.07  RHe 2015/04/16   Added timing exception for audio drop signal
2) hdmi_acr_ctrl.xdc
# Xilinx, Inc.
# the audio clock rate regenerator used in the HDMI Audio Clock Regeneration model.
# 1.00  RHe 2014/12/09   First release
# 1.02  RHe 2015/04/14   Added timing exception for audio reset
# 1.03  RHe 2015/07/31   Added timing exception for tmds clock ratio indication
set_false_path -from [get_cells -hier -filter {name=~*HDMI_ACR_CTRL_AXI_INST/rEnab_ACR_reg}] \
               -to   [get_cells -hier -filter {name=~*aud_enab_acr_sync_reg[0]}]
set_false_path -from [get_cells -hier -filter {name=~*HDMI_ACR_CTRL_AXI_INST/rACR_Sel_reg}] \
               -to   [get_cells -hier -filter {name=~*aud_acr_sel_sync_reg[0]}]
set_false_path -from [get_cells -hier -filter {name=~*HDMI_ACR_CTRL_AXI_INST/rTMDSClkRatio_reg}] \
               -to   [get_cells -hier -filter {name=~*aud_tmdsclkratio_sync_reg[0]}]
set_false_path -from [get_cells -hier -filter {name=~*PULSE_CLKCROSS_INST/rIn_Toggle_reg}] \
               -to   [get_cells -hier -filter {name=~*PULSE_CLKCROSS_INST/rOut_Sync_reg[0]}]
set_false_path -from [get_cells -hier -filter {name=~*HDMI_ACR_CTRL_AXI_INST/rAud_Reset_reg}] \
               -to   [get_cells -hier -filter {name=~*aud_rst_chain_reg[*]}]
# Clock crossing of the N value from the AXI clock to the Audio clock
set_false_path -from [get_cells -hier -filter {name=~*NVAL_CLKCROSS_INST/rIn_Data_reg[*]}] \
               -to   [get_cells -hier -filter {name=~*NVAL_CLKCROSS_INST/rOut_Data_reg[*]}]
set_false_path -from [get_cells -hier -filter {name=~*NVAL_CLKCROSS_INST/rIn_DValid_reg}] \
               -to   [get_cells -hier -filter {name=~*NVAL_CLKCROSS_INST/rOut_DValid_Sync_reg[0]}]
set_false_path -from [get_cells -hier -filter {name=~*NVAL_CLKCROSS_INST/rOut_ACK_reg}] \
               -to   [get_cells -hier -filter {name=~*NVAL_CLKCROSS_INST/rIn_ACK_Sync_reg[0]}]
# Clock crossing of the CTS value from the HDMI clock to the AXI clock
set_false_path -from [get_cells -hier -filter {name=~*CTS_CLKCROSS_ACLK_INST/rIn_Data_reg[*]}] \
               -to   [get_cells -hier -filter {name=~*CTS_CLKCROSS_ACLK_INST/rOut_Data_reg[*]}]
set_false_path -from [get_cells -hier -filter {name=~*CTS_CLKCROSS_ACLK_INST/rIn_DValid_reg}] \
               -to   [get_cells -hier -filter {name=~*CTS_CLKCROSS_ACLK_INST/rOut_DValid_Sync_reg[0]}]
set_false_path -from [get_cells -hier -filter {name=~*CTS_CLKCROSS_ACLK_INST/rOut_ACK_reg}] \
               -to   [get_cells -hier -filter {name=~*CTS_CLKCROSS_ACLK_INST/rIn_ACK_Sync_reg[0]}]
# Clock crossing of the CTS value from the HDMI clock to the Audio clock
set_false_path -from [get_cells -hier -filter {name=~*CTS_CLKCROSS_AUD_INST/rIn_Data_reg[*]}] \
               -to   [get_cells -hier -filter {name=~*CTS_CLKCROSS_AUD_INST/rOut_Data_reg[*]}]
set_false_path -from [get_cells -hier -filter {name=~*CTS_CLKCROSS_AUD_INST/rIn_DValid_reg}] \
               -to   [get_cells -hier -filter {name=~*CTS_CLKCROSS_AUD_INST/rOut_DValid_Sync_reg[0]}]
set_false_path -from [get_cells -hier -filter {name=~*CTS_CLKCROSS_AUD_INST/rOut_ACK_reg}] \
               -to   [get_cells -hier -filter {name=~*CTS_CLKCROSS_AUD_INST/rIn_ACK_Sync_reg[0]}]
3) hdmi_example_zcu106.xdc
## Constraints for HDMI 2.0 on ZCU106
## Version 1.0
## Pins
## Video Clock SI570
#set_property PACKAGE_PIN U10 [get_ports DRU_CLK_IN_clk_p]; # USER_MGT_SI570_CLOCK1_C_P
set_property PACKAGE_PIN W10 [get_ports DRU_CLK_IN_clk_p];
create_clock -name dru_mgt_refclk -period 6.400 [get_ports DRU_CLK_IN_clk_p]
## External Reset (CPU_RESET)
set_property PACKAGE_PIN G13 [get_ports reset]
set_property IOSTANDARD LVCMOS18 [get_ports reset]
## HDMI RX
set_property PACKAGE_PIN AC10 [get_ports HDMI_RX_CLK_P_IN]; #revB
create_clock -name rx_mgt_refclk -period 3.367 [get_ports HDMI_RX_CLK_P_IN]
set_property PACKAGE_PIN M10 [get_ports RX_HPD_OUT];
set_property IOSTANDARD LVCMOS33 [get_ports RX_HPD_OUT];
set_property PACKAGE_PIN M9 [get_ports RX_DDC_OUT_scl_io]; #HDMI_RX_SNK_SCL
set_property IOSTANDARD LVCMOS33 [get_ports RX_DDC_OUT_scl_io];
set_property PACKAGE_PIN M11 [get_ports RX_DDC_OUT_sda_io]; #HDMI_RX_SNK_SDA
set_property IOSTANDARD LVCMOS33 [get_ports RX_DDC_OUT_sda_io];
set_property PACKAGE_PIN G14 [get_ports RX_REFCLK_P_OUT]; # HDMI_REC_CLOCK_C_P
set_property IOSTANDARD LVDS [get_ports RX_REFCLK_P_OUT];
set_property PACKAGE_PIN M8 [get_ports RX_DET_IN]; # HDMI_RX_PWR_DET
set_property IOSTANDARD LVCMOS33 [get_ports RX_DET_IN]
## HDMI TX
set_property PACKAGE_PIN AD8 [get_ports TX_REFCLK_P_IN]; #HDMI_SI5324_OUT_C_P
create_clock -name tx_mgt_refclk -period 3.367 [get_ports TX_REFCLK_P_IN]
set_property PACKAGE_PIN G21 [get_ports HDMI_TX_CLK_P_OUT] ; #HDMI_TX_LVDS_OUT_P
set_property IOSTANDARD LVDS [get_ports HDMI_TX_CLK_P_OUT]
set_property PACKAGE_PIN N13 [get_ports TX_HPD_IN]; #HDMI_TX_HPD
set_property IOSTANDARD LVCMOS33 [get_ports TX_HPD_IN]
set_property PACKAGE_PIN N8 [get_ports TX_DDC_OUT_scl_io]; #HDMI_TX_SRC_SCL
set_property IOSTANDARD LVCMOS33 [get_ports TX_DDC_OUT_scl_io]
set_property PACKAGE_PIN N9 [get_ports TX_DDC_OUT_sda_io]; #HDMI_TX_SRC_SDA
set_property IOSTANDARD LVCMOS33 [get_ports TX_DDC_OUT_sda_io]
## HDMI TX
set_property PACKAGE_PIN N12 [get_ports fmch_iic_scl_io]; #HDMI_CTL_SCL
set_property IOSTANDARD LVCMOS33 [get_ports fmch_iic_scl_io]
set_property PACKAGE_PIN P12 [get_ports fmch_iic_sda_io]; #HDMI_CTL_SDA
set_property IOSTANDARD LVCMOS33 [get_ports fmch_iic_sda_io]
## Misc
#GPIO_LED_0_LS
set_property PACKAGE_PIN AL11 [get_ports {LED0}]
#Only LED 0 is used at the moment
##GPIO_LED_1_LS
#set_property PACKAGE_PIN AL13 [get_ports {LED1}]
##GPIO_LED_2_LS
#set_property PACKAGE_PIN AK13 [get_ports {LED2}]
##GPIO_LED_3_LS
#set_property PACKAGE_PIN AE15 [get_ports {LED3}]
##GPIO_LED_4_LS
#set_property PACKAGE_PIN AM8  [get_ports {LED4}]
##GPIO_LED_5_LS
#set_property PACKAGE_PIN AM9  [get_ports {LED5}]
##GPIO_LED_6_LS
#set_property PACKAGE_PIN AM10 [get_ports {LED6}]
##GPIO_LED_7_LS
#set_property PACKAGE_PIN AM11 [get_ports {LED7}]
set_property IOSTANDARD LVCMOS12 [get_ports {LED0}]
#set_property IOSTANDARD LVCMOS12 [get_ports {LED1}]
#set_property IOSTANDARD LVCMOS12 [get_ports {LED2}]
#set_property IOSTANDARD LVCMOS12 [get_ports {LED3}]
#set_property IOSTANDARD LVCMOS12 [get_ports {LED4}]
#set_property IOSTANDARD LVCMOS12 [get_ports {LED5}]
#set_property IOSTANDARD LVCMOS12 [get_ports {LED6}]
#set_property IOSTANDARD LVCMOS12 [get_ports {LED7}]
set_property PACKAGE_PIN H8 [get_ports SI5324_RST_OUT]; #HDMI_SI5324_RST
set_property IOSTANDARD LVCMOS33 [get_ports SI5324_RST_OUT]
set_property PACKAGE_PIN G8 [get_ports SI5324_LOL_IN]; #HDMI_SI5324_LOL
set_property IOSTANDARD LVCMOS33 [get_ports SI5324_LOL_IN]
set_property PACKAGE_PIN N11 [get_ports TX_EN_OUT]; #HDMI_TX_EN
set_property IOSTANDARD LVCMOS33 [get_ports TX_EN_OUT]
## End
#####cd ..
#set_property PACKAGE_PIN E4 [get_ports {HDMI_RX_DAT_P_IN[0]}]
#set_property PACKAGE_PIN D6 [get_ports {HDMI_RX_DAT_P_IN[1]}]
#set_property PACKAGE_PIN B6 [get_ports {HDMI_RX_DAT_P_IN[2]}]
##USER_SMA_GPIO_P
#set_property PACKAGE_PIN H27 [get_ports {SMA0}]
##USER_SMA_GPIO_N
#set_property PACKAGE_PIN G27 [get_ports {SMA1}]
##USER_SMA_CLOCK_P
#set_property PACKAGE_PIN D23 [get_ports {SMA2}]
##USER_SMA_CLOCK_N
#set_property PACKAGE_PIN C23 [get_ports {SMA3}]
#set_property IOSTANDARD LVCMOS33 [get_ports {SMA0}]
#set_property IOSTANDARD LVCMOS33 [get_ports {SMA1}]
#set_property IOSTANDARD LVCMOS33 [get_ports {SMA2}]
#set_property IOSTANDARD LVCMOS33 [get_ports {SMA3}]
#set_property IOSTANDARD LVCMOS18 [get_ports TX_CLKSEL_OUT]
#set_property PACKAGE_PIN E22 [get_ports TX_CLKSEL_OUT]
#set_property IOSTANDARD LVCMOS18 [get_ports RX_I2C_EN_N_OUT]
#set_property PACKAGE_PIN G24 [get_ports RX_I2C_EN_N_OUT]
But the Pin HDMI_TX_DAT_P_OUT[0] is not mapped here...
