Visitor thuberty
Place and Route Issues with 64-bit version of ISE
On my Virtex 5, Place and Route in the 64-bit version of ISE 13.2 finishes, but fails.  However, the same step works in the 32-bit version.  To alleviate the need to switch between the 32- and 64-bit versions, how can I debug this?
Re: Place and Route Issues with 64-bit version of ISE
You can compare the checksum values at the various placement phases to see where the two runs diverged. If the first checksum is different then the problem is upstream of placement. If the last checksum is the same but you get different utilization in the summary, then it's something downstream of placement.
If you are copying the project files between machines make sure that you are not running ngdbuild with time stamp dependency.
As mentioned in the previous post try using the switch -nt on in ngd build command line properties.
Also check the link http://www.xilinx.com/support/answers/23904.htm which can be useful for your case, since the run is different in different environments i.e 32 bit and 64 bit.
Anirudh
Anirudh
