Visitor rfjhh_utsjr
Plan ahead doesn't start
I'm implementing a vhdl project in ISE web pack. The synthesize process is ok, but the plan ahead doesn't start. I have the same  ISE installation in other laptop an I don't have problems in Implementing design.
My students have the same problem.
Somebody may tell me what's going on please.
Re: Plan ahead doesn't start
Hi @rfjhh_utsjr,
Which OS are you running the tool in?
Please mark the appropriate answer as "Accept as solution" if information provided is helpful.
Give 'Kudos' to a post which you think is useful and reply oriented.
Hi @rfjhh_utsjr,
Also did you invoke Planahead from tool? Try to run it standalone?
Any messages in console?
Did you try invoking for IO planning pre-synthesis?
@rfjhh_utsjr,
Can you open the ISE command prompt and type "planAhead" and see if it opens the planahead GUI..
-_Syed
Visitor rfjhh_utsjr
Windows 10 in both laptops.
In my laptop ("old one") I've been working well, not in the new one, same OS.
Hi @rfjhh_utsjr,
Xilinx does not officially support using Windows 8.1 or Windows 10 with ISE Design Suite AR18419.
Since the factory have not tested ISE in Win10, they are not sure of the stability of the tool in unsupported OS. Thus even if it gets installed, it becomes very difficult to debug especially in case of any issue related to crash/hang, tool does not start etc.
Are there any messages you see in console? Did you try what @syedz suggested?
Visitor rfjhh_utsjr
I can't access c:\xilinx\14.7
A message is displayed: "can't find the specified path"
Visitor rfjhh_utsjr
I performed C:\Xilinx\14.7\ISE_DS>planahead and a message is displayed
"planAhead stopped working, Windows is looking for a solution"
Visitor rvictor
  Have the same problem with Windows 10 64 bit. Everything was working OK in August, now it does not start - the dialog with options "Close / Debug" is displayed immediately after start.
  Choosing the "Debug" option results in "Unhandled exception at 0x00007ffcd405775f in planAhead.exe: 0xC0000374: A heap has been corrupted." message and after the "Continue" button is pressed the application starts. The stack does not shows any useful information on the first look, but at least it works for me in this ugly way.
Hi @rvictor,
Sorry for the inconvenience caused in running ISE/PlanAhead in Win10 system which is not supported OS. (link). As discussed above, since factory have not tested ISE in Win10, they are not sure of the stability of tool in this OS.
prathikm
Visitor rvictor
  Yes, I quite understand that you do not support Windows 10, but the current situation is that you cannot use Windows 7/2008 on modern computers (the Microsoft does not support Windows 7/2008 for "new" CPUs, so it refuses to run on my uprated i7-7700 PC). The result is that the PlanAhead is effectively becomes unusable under Windows OS, which makes it a bit painful for developers which requires Windows OS as their primary development environment.
  To continue the use of PA requires some additional workarounds, like using it under Linux in VM, or, as in my case - ignoring exceptions in debugger.
For anyone finding this Thread via Google (like me):
A solution is to go to [ISE install dir]/14.7/ISE_DS/PlanAhead/bin and open planAhead.bat in an editor.
Then change the last line to
call "%RDI_BINROOT%/loader.bat" -exec %RDI_PROG% %* -m32
by appending the -m32 in the end. This will make ISE open PlanAhead's 32bit Version which works fine on my Win 10 x64
Hope I could help,
Felix
Visitor lf.xilinx
This worked for me. No more "planAhead has stopped working" messages .Thank you!
It seems to me that I've seen this very late, but I wanna post the best solution that worked for me, so maybe it can help others :)
1)Open C:\Xilinx\14.7\ISE_DS\PlanAhead\bin and rename rdiArgs.bat to rdiArgs.bat.orig
2)Download the zip file from : https://www.eevblog.com/forum/microcontrollers/guide-getting-xilinx-ise-to-work-with-windows-8-64-bit/?action=dlattach;attach=102040
3)Extract it. You should now have a file named rdiArgs.bat
4)Copy the new rdiArgs.bat file to C:\Xilinx\14.7\ISE_DS\PlanAhead\bin
Newbie buttercup
hanieh,
Just wanted to thank you for doing this. I too am late to this issue, but your fix worked perfectly for me
Thank you for taking the time to document this.
Cheers
your welcome, I'm glad I could help you:)
Visitor vishnu27@n
in planahead there is no file like .bat
Visitor vishnu27@n
it is rdiArgs.sh file
Visitor obi007
Works perfectly for me. Thanks for sharing your experience
