nixiebunny
Print a device image
Hi. I am attempting to help a colleague examine a big FPGA design that I am having some trouble with. I want to make an image file of the device floorplan to send to him. I can take a screen print of the displayed image in Paint, but the aspect ratio is wrong, and the resolution is lousy.
I am using Linux Vivado 2015.4.
I figured that I'd try the 'print' function while displaying the Device tab. This gives me a print dialog box that has most of the necessary settings. The printout even works! However, one setting that is missing is the size, scale factor, zoom, whatever you wish to call it. The result? Comical.
Is there a solution?
