Visitor hyknight
Problem ISE10. to ISE 13.
Hi all,
last time, i use ISE10.1 in my projects
Now,, i use ISE 13.1.
When i run old project on ISE 13.1. I have problems.
Reading NGO file "D:/Sourse FPGA/Source 13.1/10.VGA/VGATest/VGATest.ngc" ...
EXCEPTION:Xdm:FileReader.c:3040:$Id: FileReader.c,v 1.44 2010/03/15 18:33:38 jdl
   Exp $ - D:/Sourse FPGA/Source 13.1/10.VGA/VGATest/VGATest.ngc: internal read
   error around offset 479 (x1df), expected x3b ';' but found x3d '='. This
   usually occurs because the input file is corrupt.
FATAL_ERROR:NgdBuild:Portability/export/Port_Main.h:159:1.6 - This application
   has discovered an exceptional condition from which it cannot recover.
   Process will terminate. For technical support on this issue, please open a
   WebCase with this project attached at http://www.xilinx.com/support.
Process "Translate" failed
 My project is true, I don't understand.
Can you guide me ?
Re: Problem ISE10. to ISE 13.
If you do not have enough disk space on C: (regardless of where ISE is installed), synthesis generates a corrupt .ngc file.
Just try this out I hope this will help.
Visitor hyknight
Free Space in C: is 6.73G
Is it problem ?
Visitor hyknight
Now, free space in C: is 10.8 G.
but the situation is still the same
Can you attach your files so that I can reproduce your issue at my end then I will be able to tell the debugging steps.
Visitor hyknight
I attach my files.
Thanks for uploading the files.
And I have seen the files in ISE 13.1.There was no error.
You try one thing create a new project and add your .vhd file and ucf file with the selection of same Device which you have selected earlier.
Try it once there should not be any error.
Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful.So that it will be easy for others to find the solution.
Visitor hyknight
I creat a new project and add .vhd file and .ucf file with the selection of same Device. ( ISE 13.1 )
But it is error.    :(
I have attached the design files which I have used.Just check it out.
If it still show any kind of error then let me know.
Visitor hyknight
I checked it.
You can see picture in attachment.
By mistaken I have attached the same file.
Use this archived project files.
Check whether the error still there.
Just open the project directly with ISE 13.1
Visitor hyknight
The error still there
You can see attachment.
Can you try using a different machine at your end?
Deepika.
Deepika.
