Problem with Critical Warning [Constraints 18-5]
When I open the FloorPlan Area/IO/Logic (PlanAhead), Critical Warnings appear as below
CRITICAL WARNING: [Constraints 18-5] Cannot loc instance 'dl/g_carry4[0].g_firstcarry4.cmp_CARRY4' at site SLICE_X8Y8, Routing contention at pips element DOUTMUX [C:/Users/John/Desktop/expand_test4/Carry_Delay_v3_for Timing Report Generate/carry_v.ucf:25]
CRITICAL WARNING: [Constraints 18-5] Cannot loc instance 'dl/g_fd[0].cmp_FDR_O_1' at site SLICE_X9Y8, Instance placement is not aligned with its shape [C:/Users/John/Desktop/expand_test4/Carry_Delay_v3_for Timing Report Generate/carry_v.ucf:122]
CRITICAL WARNING: [Constraints 18-5] Cannot loc instance 'dl/g_fd[1].cmp_FDR_O_1' at site SLICE_X9Y8, Instance placement is not aligned with its shape [C:/Users/John/Desktop/expand_test4/Carry_Delay_v3_for Timing Report Generate/carry_v.ucf:124]
CRITICAL WARNING: [Constraints 18-5] Cannot loc instance 'dl/g_fd[2].cmp_FDR_O_1' at site SLICE_X9Y8, Instance placement is not aligned with its shape [C:/Users/John/Desktop/expand_test4/Carry_Delay_v3_for Timing Report Generate/carry_v.ucf:126]
what dose these 2 errors means??
1. Routing contention at pips element DOUTMUX
2. Instance placement is not aligned with its shape
Re: Problem with Critical Warning [Constraints 18-5]
Hi @kimjaewon
I will answer the questions in-line below:
Routing contention would mean that there are two logical nets that need to use the same physical resource, but cannot. This looks to be at the output of a SLICE site.
The shape refers to a PlanAhead internally generated relatively placed macro that helps the placer complete its task. The shape not being aligned would mean the constraints on the logical cells is not physically possible. I would check the constraints referenced.
Hi @kimjaewon
