Newbie schreiberm
Problem with Virtex 2 Block Ram symbols in Xilinx 9.2 - 10.1.03
I have an old schematic based (viewlogic) Virtex 2 design that was originally built with XIlinx 6.x.  I need to make some slight modification and I would prefer to make the changes in a more recent version of the Xilinx tools.  I am taking an old .edf netlist and running it through the ISE 9.2.  I get errors during translate....this is the error that I get:
ERROR:LIT:239 - Attribute INITP_00 on RAMB16_S9_S9 instance
   "$2I2821/$1I2113/$1I5275" has an invalid hexadecimal value,
   "X0000000000000000000000000000000000000000000000000000000000000000".
I also tried the design on a colleagues machine using ISE 10.1.03.....same error.
If I open the schematic containing the block ram, I see that the above attributes are contained in the viewlogic symbol.
A colleague had similar problems when retargeting a similar design to a virtex 5.  I can understand this issue in a virtex 5 device because this symbol is no longer supported in Virtex 5, but I would think that the tool should still support the virtex 2 library.  I know no one uses schematic design anymore, but any help would be appreciated.
Mike
Historian
Historian
Re: Problem with Virtex 2 Block Ram symbols in Xilinx 9.2 - 10.1.03
I haven't looked at ViewLogic since the bad old DOS days, but I suspect that:
is the problem because it is not a valid hexadecimal value.
Perhaps it needs to be
X"0000000000000000000000000000000000000000000000000000000000000000"
Newbie schreiberm
Yeah I noticed the invalid VHDL notation of "X0000000" vs X"00000", but this is generated by the Xilinx Viewlogic symbols, and previously worked with the earlier versions of the Xilinx tools.  Thanks for the input....much appreciated.
Mike
Historian
Historian
Mike
The old tools might have accepted the bad syntax, whereas the newer versions correctly barf on it.
-a
Newbie schreiberm
I was able to edit the symbols and remove all the "X"'s in the symbol files.  I then was able to route the design.  I believe those values are only used for simulation purposes.  Seems to be working ok.   Thanks for your help.
