asenapati
Problem with implementation of a latch in Virtex5
I intend to implement a latch using the following lines:
always@(*)
     begin
         if(resetz==0)
           in_cic_d1 = 0;
         else if(count==3'sb000)
           in_cic_d1 = out_cic_i3;
      end
   always@(negedge(clk_adc) or negedge(resetz))
   begin
    if(resetz == 0)
       count<=0;
    else if (!clk_adc)
       count<=count+3'sb001;
   end
Desired: if count=000, in_cic_d1 = out_cic_i3; if count is anything other than 000, in_cic_d1 should hold the value of in_cic_d1 at the previous 'count=000'.
What i see in vsim: What is desired.
What i am seeing on fpga chipscope: (Pls. find attached). The latch holds some random value.
How can i modify the code to get the desired response in Virtex 5?
I need to use a latch and not a flipflop. Any help would be appreciated.
asenapati
balkris
check this old document for example
http://www.xilinx.com/itp/xilinx10/books/docs/xst/xst.pdf
Thanks and Regards
Balkrishan
gszakacs
Instructor
Instructor
The code as described uses a gated signal as the latch gate.  Whenever the counter updates, due to variance in routing delays there can be different delay times for different bits of the counter to reach the AND gate.  This means that at any clock edge where the transitioning counter outputs pass through a state you're trying to decode, you can get a glitch on the latch gate.  If you really want a latch and not to use the clock, you need to supply the gate to the latch from the Q output of a single flop.  The D equation for that flop needs to anticipate the state when the counter will be the desired value, in your case 3'b000.
something like:
   begin
    if(resetz == 0)
       count<=0;
       latch_gate <= 1;
    else if (!clk_adc)
       if (count == 3'sb111) latch_gate <= 1;
       else latch_gate <= 0;
   end
-- Gabor
asenapati
@gszakacs
Thanks a lot for replying.
I modified the code as you mentioned.
   begin
    if(resetz == 0)
       count<=0;
       latch_gate <= 0;
    else if (!clk_adc)
   end
always@(*)
     begin
         if(resetz==0)
           in_cic_d1 = 0;
         else if(latch_gate)
     end
Problem: Now, the latch doesn't even sample the correct value when latch_gate=1 (using ISE). I am not sure, what i am doing wrong. PFA the screenshot.
asenapati
asenapati
@balkris
Thanks a lot. It's a very useful link.
I am already doing what has been mentioned in the link. But the problem is how the input to the latch are generated.
gszakacs
Instructor
Instructor
Judging from the ChipScope screen shot, it looks like this is an inappropriate use of a latch.  If the inputs to the latch are changing on every clock cycle, the latch won't work as intended because the latch gate shuts off a bit after the clock edge when the latch D inputs are potentially changing.  Perhaps it would help if you described why you want to use a latch and how you're going to use the outputs of the latch in the system.  Usually there will be another way to implement what you want without using a transparent latch.
-- Gabor
asenapati
I want to use the latch as a downsampler. A latch not a flipflop to avoid one or half cycle delay.
gszakacs
Instructor
Instructor
If all you want to do is avoid an extra cycle of latency, you can use a combination of a flip-flop and multiplexer to emulate the latch.  This works as long as the inputs and outputs are synchronous to the clock.  Something like:
  begin
    if(resetz == 0)
      begin
        count<=0;
        latch_gate <= 0;
        held_data <= 0;
      end
    else if (!clk_adc)
      begin
          begin
            latch_gate <= 1;
          end
        if (latch_gate) held_data <= out_cic_i3;
      end
  end
always@(*)
     begin
         if(latch_gate) in_cic_d1 = out_cic_i3;
         else in_cic_d1 = held_data;
     end
-- Gabor
