Visitor danhdoanes
Problem with ucf file
Hi everyone,
I have a problem that is: if I remove I/O buffers (on Process Properties - Xilinx Specific Options), then I cannot Translate my design. From the .ucf file, it says some of my I/O is not found.
Can you guys give my some advice
Thanks in advance
Re: Problem with ucf file
I hope I understand your question right, but my first impression would be that you have assigned some pins in UCF files with I/O ports of your design. But in your design you have removed the I/O buffers so these ports are not connected any more to any logic. It can happen that the synthesis tool remove unconnected signals.
I wish if you clarify more about your UCF PIN assignment and your design I/O ports.
