gquan
Problems with lab 3 in XUP workshop materials on Embedded System Design Flow on Zynq using Vivado 2017.4
I am new to Vivado and am trying to test XUP labs on "Embedded System Design Flow on Zynq using Vivado" (2015x). I installed Vivado 2017.4 and successfully finished lab 1 & 2. However, when I tried lab 3, I had problems to generate the bitstream, with the screenshot for the error messages attached. Can somebody please tell me how I can solve the problem?
Also, the lab 3 only has instructions on how to program customized IP (i.e. led_ip) using Verilog. Can anyone help me with the instructions and source code to program the same IP using VHDL? Thank you.
gquan
Hello harshit,
Thanks for responding to my questions. In fact, I was trying to use the same constraint file downloaded from the website as you indicated. Now I found the problem: in lab 3 instruction, after step 3-1-9 to make the LED port of led_ip external, we need to change its default name from LED_0[3:0] to LED[3:0]. That solves the problem. Thank you anyway for your answer.
hj
Check this AR https://www.xilinx.com/support/answers/56354.html
The error message is to notify customers that they need to set IOSTANDARD and PACKAGE_PIN, in order to protect devices from accidental damage that could be caused by the tools randomly choosing a pin location or IOSTANDARD without knowledge of the board voltage or connections.
Here is the link to source file https://www.xilinx.com/support/documentation/university/vivado/workshops/vivado-embedded-design-flow-zynq/materials/2015x/2015_2_zynq_sources.zip If you have access to this page you would be able to download it.
Link for all the labs and design files https://www.xilinx.com/support/university/vivado/vivado-workshops/Vivado-embedded-design-flow-zynq.html
For more information please refer to configuration resources https://forums.xilinx.com/t5/FPGA-Configuration/Configuration-Resources/m-p/753763/highlight/true#M5891
gquan
Hello harshit,
gquan
Hello harshit,
As I mentioned in my previous post, I am also trying to find the VHDL source and instructions on how to design the customized IP (led_ip) in lab 3 on Zynq using Vivado. I was told this is supposed to be trivial, but not to me. Do you happen to know how to do it? Thank you.
