Observer skor
[Pwropt 34-321] HACOOException: Too many fanin/fanouts in design, exiting pwropt. You can change this limit with the param pwropt.maxFaninFanoutToNetRatio
Hello
I am using VIVADO 2018.3 . Design optimisation stops and I get following message :
[Pwropt 34-321] HACOOException: Too many fanin/fanouts in design, exiting pwropt. You can change this limit with the param pwropt.maxFaninFanoutToNetRatio.
I started to get this message when I removed from my memory block the safety logic. i do not use RSTA_BUSY signal, so i got a warning about unused signal. tried to remove that but now optimisation fails.
What is the best way to proceed? take back the unused RSTA_Busy or try to set the param as indicated in the vivado message. How can I change the param and what shoul be a reasonable value.?
Regards,  skor
Re: [Pwropt 34-321] HACOOException: Too many fanin/fanouts in design, exiting pwropt. You can change this limit with the param pwropt.maxFaninFanoutToNetRatio
Hi @skor
The error is caused by a threshold limit being exceeded. For a net, the number of total fanin or fanout is greater than 1000. I would suggest setting this to 2000, and then 5000.
set_param pwropt.maxFaninFanoutToNetRatio 2000
Hi @skor
