eryk2303
Quantity of slices
where I can find in Vivado quantity of logic slices used in implementation?
Eryk
amaccre
Hi @eryk2303 ,
You can type report_utilization into the tcl console post opt_design or after running implementation.
You can get further information on the command by typing report_utilization -help
Best Regards
Aidan
Please mark the Answer as "Accept as solution" if this answered your question
Give Kudos to a post which you think is helpful and may help other users
bruce_karaffa
Open the implemented design and look in the Reports tab.  The utilization report is in either the optimize or placement section.  I'm running a simulation right now and can't check.
amaccre
Hi @eryk2303 ,
Best Regards
Aidan
