meg36
Regading IDELAYCTRL issue in Vivado IDE
I have attched the code in text file format, where we use IDELAYCTRL.
The bit file will get generate with the following critical warnings.
Hardware used: Kintex 7 - xc7k325tffg676-1
Please provide the solution.
hemangd
hi @meg36 ,
Have a look into this thread. https://forums.xilinx.com/t5/Other-FPGA-Architectures/How-to-set-ODELAYE2-REFCLK-FREQUENCY-Attribute/td-p/922941
This may help you out.
You will have to set the clock using create_clock constraint for ref_clock.
hemangd
