mkru
Report for optimized out logic.
Is there any way to generate a report for things that have been optimized out?
I can imagine that in such a report user would get an information what has been optimized out and why.
dpaul24
@mkru ,
Check the synthesis log file. Read it carefully.
------------FPGA enthusiast------------
Consider giving "Kudos" if you like my answer. Please mark my post "Accept as solution" if my answer has solved your problem
dsheils
You can use the -debug_log switch in both Synthesis and Implementation stages which might give you more useful info in the logfile.
mkru
@dpaul24 , @dsheils
Any useful regexes to search for?
mkru
@dsheils How to use the -debug_log switch? I do not see any information on it in the Tcl commands documentation and do not see it in the Synthesis settings in the GUI.
dsheils
Hi @mkru
In the GUI you type it in in the More Options box:
You can do the same for Implementation settings also if needed.
