Ring Oscillator with jitter of 500 -1000PPM, is this typical value?
I use 3 LUT1 in xcku040 to build a 3 stage ring oscillator. And use this clock to count in "1 second window" provided by external signal. I got a clock about 602MHz.
I found the count result is quit unstable, the variation between seconds is usually more than 500PPM, some times will reach 1000 PPM. Is this variation reasonable for LUT build ring oscillator?
Code is list, implement result and  count result is attached. Thanks
assign #1 ring_0_input = r_osc_en&ring_stage_2;
(* keep_hierarchy = "yes" *) LUT1 #(
.INIT(2'b01) // Logic function
RING_0 (
.O (ring_stage_0), // 1-bit output: LUT
.I0(ring_0_input) // 1-bit input: LUT
RING_1 (
.O (ring_stage_1), // 1-bit output: LUT
.I0(ring_stage_0) // 1-bit input: LUT
RING_2 (
.O (ring_stage_2), // 1-bit output: LUT
.I0(ring_stage_1) // 1-bit input: LUT
OSC_BUFR (
.O (osc_clk_pre ), // 1-bit output: LUT
.I0(ring_stage_2) // 1-bit input: LUT
//assign osc_clk_pre = ring_stage_1;
BUFR U_BUFR_OSC(
.I (osc_clk_pre ),
.O (osc_clk )
Re: Ring Oscillator with jitter of 500 -1000PPM, is this typical value?
That's actually more stable that I would have expected, based on my past experiments.
It would be fairly simple to adjust your setup to estimate the Allan variance to show how the frequency stability of multiple samples varies with the sample time (which is 1 second in your example).  My tests were all done with much shorter sample times (much less than 1ms), which might be why I observed much more instability.
I assume you weren't varying the temperature between measurements.  You could try that to see what difference it makes.
Also, I found that other nearby routing would affect the results.  It's not uncommon to instantiate multiple ring oscillators (e.g. when used as an entropy source) and (unless care is taken with e.g. a large physical separation and isolation design flow) these will tend to lock together, or lock to another clock on the die.  This shows up in the correlation tests on the outputs.
Hi Allan
Thanks for your suggestion. The test result is temperature stable since it's in a air-conditioning lab with only 1 board, in less than 1 hour period.
Actually this result is stably different with the result one month ago, about 1000PPM in average. May be I can test this with aircon off.
I will try to move away the adjacent logic, and see if the stability improve.
Hi Allan
I've test isolate the ring oscillator part with Pblock, seems the stability is still poor.
This picture shows the implementation result, and the PPM.
Point N's PPM is N/(Ave(N:N+499))-1)*1000000; Each point is 1 second's counting. Seems no improve.
