Routing Utilization report + congestions report
Hi All,
How can I create a Routing Utilization report + Routing Congestions report?
Thank you!
Re: Routing Utilization report + congestions report
@ldm.eth
report_design_analysis will create the initial routing congestion report and will report the utilization in the congested window.
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_3/ug906-vivado-design-analysis.pdf#page=150
--Syed
Is there a way to do the same from GUI?
@ldm.eth
Yes. Open Implemented design and select Report-->Report Design Analysis..  Make sure you select Congestion in the Report design analysis window.
If you are facing congestion in design the check the below AR and UG949:
https://www.xilinx.com/support/answers/66314.html
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_3/ug949-vivado-design-methodology.pdf#page=253
--Syed
