tim_severance
Run Post-Route Phys Opt Design
Quick question,
   Let's say I am using Vivado 2017.4 and just completed an implementation using Performance_Explore strategy but failed timing.   What is the recommended method if I wanted to run an additional Post-Route Phys Opt Design?   I believe I can open the Settings window and check mark the is_enabled in the Post-Route Phys Opt Design option and hit OK and I think it will ask if I want to continue from the last step.
   Is there a way to run this step using TCL (I am using project mode in Vivado)?
   Also, what if I wanted to run a few more iterations of Opt-Design?   Can I load a design checkpoint at the end of the Opt-Design that already ran and then using TCL tell it to run some more iterations?
Tim
jmcclusk
Mentor
Mentor
It's easy enough to run a post-route polishing pass..   Just load the design "Open Implemented Design" in Vivado, and run the optimization you want from the TCL console.
jmcclusk
Mentor
Mentor
I'd do this.
Turn on retiming in synthesis first.
Then I'd turn on Post-Placement Phys Opt.   I'd also look for timing failures involving high fanout nets, and perhaps target them specifically for post-placement optimization
and lastly,  Post-Route Phy Opt...    which can be run multiple times, by the way.
tim_severance
@jmcclusk,
   Thanks for the tips.
   Can you be more specific as to how I would run the post route phy opt multiple times?   Let's say I just ran implementation and it failed timing.   Do I need to load the implemented design and use a TCL command to run the post route phy opt again?   Or can I do it somehow through the GUI?
Tim
jmcclusk
Mentor
Mentor
It's easily done from the TCL console.  you can run the entire flow from the command line, after loading the synthesized netlist.
eg:
place_design -directive Explore
phys_opt_design -directive Explore
phys_opt_design -force_replication_on_nets [get_nets  target_net]
route_design -directive Explore
phys_opt_design -directive AggressiveExplore
tim_severance
@jmcclusk,
   Thanks for the info on how to do it all from the console.
   But what if I ran synth and impl using the buttons in the GUI but timing failed and I wanted to run additional post-route phys opt design runs.   Is this possible?   Do I have to load the implementation and run a TCL command from there?
Tim
jmcclusk
Mentor
Mentor
tim_severance
@jmcclusk,
   I took a design that failed timing, opened the implemented design and ran "phys_opt_design -directive AggressiveExplore" from tcl console and then when it completed I ran the timing report and it showed passing.
   My question is how do I get this now passed timing to show in the Project Summary page and WNS/TNS in the Design Runs tab?   Once I closed the implementation Vivado still thought timing failed.
Tim
jmcclusk
Mentor
Mentor
try adding this pass as a post-route command in the implementation options.  see below:
tim_severance
@jmcclusk,
   Sorry for the delay on this, but I am again working on optimizing timing on a complex design.
   You mentioned adding in the post-route phys_opt_design, but I already had that setup when I initially ran (which failed timing), then I opened the implemented design and ran more phys_opt_design runs where it eventually passes timing.
   I then save the implementation and close it.
   My question is how do I get the report shown on the main Project Manager (Design Runs tab) to show updated reported WNS/TNS/WHS etc.?   The numbers shown there are still the original failing numbers.
Tim
tim_severance
@jmcclusk,
    As an example:
   I synthesized a design using "Flow_PerfOptimized" synthesis strategy and implemented using Performance_ExplorePostRoutePhysOpt implementation strategy and ended up with WNS=-0.030 and TNS=-0.066.   I then opened the implementation and ran "phys_opt_design -directive AggressiveExplore" which ended up with WNS=+0.006 and TNS=0.000 so it passed!
   I then click the X in the upper right corner of Vivado to close the implemented design and it does not ask if I should save, it just lets me close..
   The WNS and TNS still show -0.030 and -0.066 in the design_runs window.
   If I open the implemented design again then the timing is back to where it failed initially, so my additional phys_opt_design I ran before was not saved.
Thanks for any tips to get this working.
Tim
jmcclusk
Mentor
Mentor
This is straightforward..    Once you've modified a design in memory like this, in order to save the results, you have to save it as a design checkpoint (DCP) file.     use the TCL command "write_checkpoint <file>"
tim_severance
@jmcclusk,
   Thanks for the fast response.   Do you know if this updates the summary numbers in the Design Runs tab?
Tim
jmcclusk
Mentor
Mentor
No it won't.     Once you start diverging from the standard design flow, Vivado doesn't really keep track of what you are doing.
tim_severance
@jmcclusk,
  Ok, understood.
  If I save a design checkpoint and then close implementation, will this checkpoint open when I open that implementation next time from the main window, or will it still open the implementation that completed before I ran the post-implementation phys_opt_desing?   In other words, is the only way to open the design with the passing timing going to be by doing a file->Checkpoint->Open?
Tim
jmcclusk
Mentor
Mentor
you got it..   file->Checkpoint->Open  is how you reload a design checkpoint.     you might be able to shoehorn your modified design flow into the standard Vivado design flow by using pre/post TCL scripts..      These can call the post-route phy_opt_design, for example, after routing.   Then you should get the right reporting in the various reports as well.
tim_severance
@jmcclusk,
   Great idea with the post.tcl.   I could put in calls to a couple extra rounds of phys_opt_design.
   Thanks for your help, you have been really helpful.
   Technically the thread is already closed with an accepted solution.
Tim
andrewcb
My 2019.1 project flow failed to run phys_opt_degin as Vivado thought there were not timing errors, despite the Implementation Timing Report showing 32 errors!!
I was able to use this post to run phys_opt_design manually and it was able to fix the timing errors in just 4 passes.
Thank-you.
